Drivers /  parameters for ripole subs
Old 14th March 2016, 03:41 PM   #231
Kjeldsen is offline Kjeldsen  Denmark
Why is it that high Mms is not good for Ripoles?
http://kjeldsensforbindelser.dk
Old 3rd September 2019, 12:55 PM   #232
DaveFred is offline DaveFred  Canada
Originally Posted by bibster View Post
Well,
Here's my Q'n'D ripole calc sheet, mainly for cabinet construction though...
It's a preliminary V0.0001 alpha release
Send comments/improvements etc. to my email rather than here, I don't want to mess up this usefull thread!
regards, (Ri)Paul
Has anyone built a ripole using this spreadsheet?
How were the results?
Old 6th September 2019, 10:27 AM   #233
ThorzHammer is offline ThorzHammer  United States
Wouldn't that spreadsheet just be for a simple folded dipole design?
It's my understanding that a true "Ripole" design (short for Axel "Ridtahler's Dipole") uses dual subs in an opposing push/push configuration where the front of each sub fires into a common center chamber and the rear of each sub fires into it's own dedicate chamber. That's what I recently built using a pair of Infinity REF1200S Low-Profile subwoofers so I wouldn't have to see those ugly magnets sticking out the sides of the enclosures.
Old 6th September 2019, 10:52 AM   #234
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
It pulls down sensitivity.
Don't Procrastinate....Just Do It!
Old 6th September 2019, 12:04 PM   #235
Any measurements?
Old 6th September 2019, 12:37 PM   #236
I use a MiniDSP DDRC-24 in my setup for room correction. According to the frequency response from it a single Ripole sub (the 2nd is in it’s finishing stages) along with my Magnepan 1.5QRs are flat down to 27Hz. While this doesn’t go down into pipe organ territory (I don’t listen to that sort of thing anyway) it is a HUGE improvement over my Maggies alone. I agree with a statement made by “Jazzman” (Google “Jazzman’s Ripole") that you should not expect chest thumping, room shaking bass like you would hear at a movie theater from a Ripole. Taking that into consideration the added bass provided by the Ripole sub blends beautifully with my Maggies.
Old 17th October 2019, 10:43 PM   #237
Originally Posted by Rudolf View Post
The rule of thumb here is: If the drivers Xmax (peak-to-peak) is >10 mm, the opening area of the pipe should be not less than 1/3 Sd. If Xmax is less, the area might be reduced down to 1/4 Sd.
Rudolf
This does not make sense to me.
I thought X-Max was one way and peak to peak was both ways.
Drivers /  parameters for ripole subsHide this!Advertise here!
TS parameters and specs for these drivers??? Bull Multi-Way 1 9th March 2011 01:15 PM
T/S parameters for horn drivers buggsson Multi-Way 7 25th March 2008 09:53 AM
Parameters for drivers iwahn Subwoofers 0 20th June 2007 10:13 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 2nd August 2004 12:33 AM
T/S parameters of JBSystems drivers sstoiana Multi-Way 1 30th September 2003 09:11 PM
Copyright ©1999-2019 diyAudio
