Circlomenen, can we locate 8th order qw as a function of the speed of sound?
Speed of lihggg :299792458kms. Or 29, 979.2458 in one second instead of the 1000. 500 to earth makes the actual distance to earth 1496. So if we say 30 we mean 29.979 etc. etc.
And if we say 75 we mean 74948 whatever same goes for the other numbers 20 249…
So , 7.5 , 15,22.5, 30. And established four part series on speed of light.
speed of light ,halfway to earth and earth then right on top of Mars and then right back to us.
If there’s a pendulum fulcrum point at the driver set an a line they pull it back to 30 and let it swing to 30 again in one second we have a seSequence of 30 and so then at 90 we are effectively in the center of pressure phase I try to position it goes to the closest wall then back across the driver again and then two more 30s to90.
Repeat that four times and have her do the opposite from the other side it only 90. you have 360 total. .
That you have 13 parts of the sequence sink perfectly for some reason that creates a complete cancellation of sound at 860 hurts and it repeats at that interval at 860 over and over and over again forever. Last seen before exceeding 20,000 at 19780 Hertz. And in between at 12,24,36,(48 , 96,192) it has another ripple like to fournier transform does.
If you hold the button down in your mouth and watch the numbers as they fly through -990 DB at those 860 dumps between lesser rolls, begin to observe the sensation not unlike sitting on the surfboard waiting for the perfect way to come in but feeling all of them that role underneath you or over you while looking for the perfect one which inevitably seems to come at a certain number that is an automatic. ?
We can take all of that and place it into the series path. Using the same 30 where are using 120 and two40 and 360.
Get the same results so awkward and strange yet seemingly perfectly aligned cancellation at 860 intervals.
And with the CSA chosen is a two-part layout for each the folded initial skinny path and the wider final resonator At 4 to 1 or 5 to 1 very delicious response emerges one that looks almost identical to the parallel which would merely be the same but taking that 5 to 1 Ratio and splitting it one more time, Sharing it with the short 90 cm parallel in that case
.Oh you’re a little bit more keen on things outside of acoustics and numbers did engage other elements of physics maybe even knows on the circle if that’s what you looked at it in the perspective of. Whatever this is this is also then representing the locations of planets in the solar system and a whole bunch of other things and that’s all based on the 860 because what that actually is is the second to the day the diameter of the sun the diameter of Jupiter and the location of Jupiter using miles or millions of kilometers or units of time on earth and also it shows the expansion rate because he’s no longer 1440As in minutes on earth or the location where Saturn would be hypothetically it’s 14620 Which is the same amount of days in the leap year of four years as degrees around the sun or not 360 but the same number applies here as a result 05238052380523805238 is the speed of light at a parallax angle which defines location of a great many things including the parsec light year and the big bang distance of visible light at that distance etc. etc. we arrive at all kinds of amazing things but in this case we’re also using that the subwoofer and look at what happens?? Which is the same amount of days in the leap year of four years as degrees around the sun or not 360 but the same number applies here as a result 05238052380523805238 is the speed of light at a parallax angle which defines location of a great many things including the parsec light year and the big bang distance of visible light at that distance etc. etc. we arrive at all kinds of amazing things but in this case we’re also using that the subwoofer and look at what happens happens???
So I build it with 212s not the best not the worst decent no doubt and it’s a monster and I build it again using the parallel version only have one more driver driver for that at the time but it to has that wicked signature to the sound which creates the upper mid subwoofer region a very violent and brutal whip like attack when you really turned over and let it move some air whatever the hell is going on in their there He’s no longer awkwardly weird creating things that formerly stirred up ringing and vibrations and drug that was very messy though inconsistent and when it would show up and we’re including which seem to be periodic areas of limited sound abbreviate sound attenuation sound or partial deconstructive interference due to folding?
We all become is so much smoother and so much more on point if you’re using the speed of light reference to do this and more and more that makes sense deeper deeper look into how and why is this cancellation of -990 occurring in the simulation who is that represent why is the entire upper band with strip naked and just left with the skeleton when otherwise it’s really looks like chaos and massive thick heavy hashmarks. We all become is so much smoother and so much more on point if you’re using the speed of light reference to do this and more and more that makes sense deeper deeper look into how and why is this cancellation of -990 occurring in the simulation who is that represent why is the entire upper band with strip Bare bonesnaked and just left with the skeleton when otherwise it’s really looks like chaos and massive thick heavy hashmarks.
I’m not sure but the pattern of this in heels if you write down all those numbers and the cancellation parts of the peaks is a sequence in that sequence goes on to me and told amounts of information in both directions past zero as well zero which is 180° out of phase of the fundamental which starts to make a lot of sense how or why you could completely go below zero in another way of thinking or another dimension or another existence so speak simply one that we are not aware of anything that we are not able to sense or understand or ever could for the reasons shown in And the layout is soSimple and it Can be extended in 30 cm increments and still provide that unique result of the -990 DB repeatedly being shown at the 860 Hz intervals.
Look at numbers on the circle in radians or degrees or centimeters of circumference they represent a bunch of weird things in many ways 15° or . 2618 we’re half of it at 1309 7.5°. This is all inside a room in the pyramid which is a perfect rectangle that describe a perfect circle. Kind a like a roar can be and still can use these same numbers to break it down?
240° on a circle is 4.188888 that is the volume of a sphere equation when radius equals one if you make a roar 360° (As cm not degrees ) And label every 15° and drop drivers on 30 and 22.5 as you may have to to satisfy the details of the supply room for the exit on the skinny path into the large I need two drivers a post from each other just to start simplifying these things and to allow the offset to exist because it would seem that that Pendulem swing set up a synchronicity that ends or begins or whatever at 360. Or whatever and every single thing including exit that must be at a 90° or 180 whatever it takes to supply a standing wave and a propagating with filtering fact or construct to do things that don’t make it through but are close in size to the oncoming and outgoing when it does in the bigger picture what is happening so rapidly in sound going through there because it changes the music etc.? I don’t know but what you see in numbers in the solar system or another things when given the chance and explain to the same in that way they start revealing the same exact numbers in phase at7.5 or 15 or 22.5 or 30 increments of 45/60/75/90/205/120….. degrees? frequency and millions of kms or millions of miles become centimeters In two seconds just like what happens in late to earth or past and back to it as if it were to visit Mars real quick? After all the distance between earth and mars is 1 to 1.152 astronomical units. And so the angle of 30° which is 0.5238095238 when used in both the subwoofer and when used from the center of the sun outward defines all of these things and if you look 1738 as a hypotenuse in a short leg of 864 please location of earth on the long leg of a right triangle which acute angle uses the speed of light is 29.9792458 produces. And so the angle of 30° which is 0.5238095238 when used in both the subwoofer and when used from the center of the sun outward defines all of these things and if you look 1738 as a hypotenuse in a short leg of 864 please location of earth on the long leg of a right triangle which acute angle uses the speed of light is 29.9792458 produces.
That seems to be the recipe for one hell of a roller or a parallel version or texting me that number shows up in an offset driver transmission line attached exit it’s inconsequential but the driver position will be 104.76 cm in 300 cm, and scene in our response that will be the exact location we’re perfectly filling the void is that for the odd harmonic of the speed of light ??
Very weird connection between circles in the metric system in circles in standard system and the fact that this represent a quarter I will be late and the speed of light or pie or the speed of light radius as well.
That will go on to show up at 11,22,33,45 mm circles which are 0.433Inch 866 inch and 1.299, 1738 version of the radius and diameter of the sun to its representation in actual 11/7 22/7 x 44/7 as radius diameter and even circumference… 90,180,360, 1.57142857142, 3.142857142, 6.2957142… An error can be seen at 176÷7 which is four circles it’s also the end of the Spins and all of qw in General, for harmonics, Thereafter in all of this. 1÷7 error keeps building and building and building after 25.142867 . And a 1.75 inch… Fits perfectly on each side of the cube tray and isometric grab paper which have 6 x 5 sides split up and each has 30 using one 1/4 :1 isometric Paper which involves the 30° speed of light
The hypotenuse of two perfect cubes that fit two spheres in them exactly that share the ratio of 52.38 % volume to each of those cubes when they were separate as to the one is 104.76 or 60° across quarter to quarter in three-dimensional mode . That number keeps repeating over and over and all kinds of areas and that number is the parallax speed of light and it keeps making all of these higher order function things because the abbreviated version is also drive a transmission line into amazingly perfect??
As it turns out six 12, 24 and 48 spheres fit on top of the original sphere which we cannot understand but we can represent mathematically visually , in those dimensions of higher math in the same way that were using it here to divide up the circle into the rectangle parts of 7.5 15 22.5 and 30 cm pieces.
The fact that the eighth order is 240 spheres which is in 240° 4.1888 in radians on the circle which is the volume of a sphere equation with a radius equal to one?
I don’t know what’s going on here exactly but clearly something is in the zone of whatever the entire solar system is because subsequently the numbers in that sequence after 860 repetitiously represent all of those things?
He works in fact I kind of like four drivers in it stacked it barely fits in a small Toyota forerunner or Land Cruiser SUV. Try to work on that exit though.., Bounce off of a parallel wall it makes so much sense when we look deeper and deeper into this I don’t know that I can afford that I can’t clear the insides of the vehicle but that makes a hell of an awesome version of this one upright inside the home And office , it works quite well with the Dayton audio TCP 115 4 inch driver add an abbreviated 45 Hz tune.
Wondering what is a magical place is in length post here in the subwoofer region of 360 but also how did they become does all this informationFrom the above and out of band sequence of dead silentFull cancellation for the product of both sides of the driver at those intervals of 860
