How good is Hornresp?
Thread Tools
Old 18th November 2021, 09:03 PM   #1
peterjohnswindley is offline peterjohnswindley  United States
Default How good is Hornresp?
So first off- I am aware that this software is free. So even if it's just a bit of fun I am definitely not complaining.
Also, I'm aware that this has probably been discussed a lot before, but cannot find any dedicated thread, other than David's pinned thread. If there is such a thread, please point me in the direction and I will duly delete this thread.
I'm working on tapped horns. My current attitude to using it is based on hoping that it 'probably gives a good general indication' of how a real built horn will sound. And I'm expecting to make at least a couple of mocks in MDF before making my final 'product'.
Is this a reasonable approach?
Are there any known ways in which the software (as excellent as I presume it is) cannot be expected to predict reality?
Old 18th November 2021, 09:17 PM   #2
stv is online now stv  Europe
stv's Avatar
If you read through the hornresp thread you will see examples of exact match between simulation and measurements. The problem is not the simulation software (it is very precise), the problem is rather how to model the loudspeaker exactly. Precise model will give precise results.
Old 18th November 2021, 09:40 PM   #3
weltersys is offline weltersys  United States
weltersys's Avatar
You can definitely expect "a good general indication" from Hornresp.
Most deviations from the simulation to the measured can be accounted for by differences between "as built" and "as simulated"- folds are not the quite same volume or length as a straight expansion, high aspect ratio rectangular shapes are not the same as a circle, exit and entrance shapes are assumed to be circular, "half space" requires one to bury the cabinet in the ground.
In addition, speaker compliance (and reduced Bl) usually progressively limits excursion past Xmax, while Hornresp (and most simulations) don't (can't) factor that in, though up to Xmax predictions should be close to measured.
Voice coil inductance can be variable, double-click on the value for Le to bring up a separate dialog box to enter the semi-inductance parameters.
The Subwoofer DIY Page - Semi-Inductance
Semi-Le_Calc: Calculator for Advanced Inductance Model Incorporating Semi-Inductance
At any rate, there are a lot of things to consider when making new designs, or even changing drivers in an old design.
Old 18th November 2021, 10:27 PM   #4
this is very impressive to hear!
Old 18th November 2021, 10:37 PM   #5
Right.
I'm using the maximum SPL feature a lot- and my design does rely on Hornresp's predictions of how the sound changes at different levels of input power.
In fact, with this design, it looks like it's quite easy to have too much headroom. It only sounds the way I intend it to between 200 and 700W. Given it is intended for a live sound reinforcement purpose, I expect I will use a good deal of the wattage.
Old 18th November 2021, 11:07 PM   #6
weltersys's Avatar
The "maximum SPL" feature is not indicative of "sound changes" at different levels of input power.
Start thinking in terms of voltage, not watts- and yes, you will want to use all the peak voltage available for live sound reinforcement.
Design so driver excursion in the pass band does not exceed Xmax at Pe, and you will be in the ballpark.
That said, a driver's AES Pe rating (in watts) is measured in free air at the voltage equivalent to driving it's nominal impedance to that level, but it's free air impedance will be far higher than in a TH.
For live use, long term "RMS" limiting with a time constant of longer than 500 ms (milliseconds) should generally be no more than half the AES ratings.
Old 19th November 2021, 02:59 AM   #7
Brian Steele is offline Brian Steele  Grenada
Hornresp does not include the effect of box losses in the TH model. As a result the actual response might look a bit "smoothed" compared to what the sim suggests it should be. You can however emulate the effect of box losses by adding a low value (1) for stuffing in each element of the sim.
Also, when the dimensions of the speaker's box come within a 1/4 wavelength of the frequencies that the speaker is trying to reproduce, there's going to be deviation from the sim, but that's true for most design programs.
Hornresp is a great tool, but it can be a bit difficult to get into it at the first. Once you learn how to use it though, you'll realize how powerful it really is. For example, do you want to model how the position of the driver and/or the position of the vent can impact the response of a vented box? Hornresp can do that...
www.diysubwoofers.org
Old 19th November 2021, 03:50 AM   #8
NeilBlanchard is offline NeilBlanchard  United States
I think the challenge using Hornresp, is that you need a good accurate way to draw the design, as you are doing iterations in Hornresp. As mentioned, it is the interpretation / translation of the design between Hornresp and the drawing - in both directions.
I am fairly new to Hornresp, and there is a steep initial learning curve. It is deep, and complex - and it usually can do everything; and its just a matter of finding how to do it. I used it for two mass loaded transmission line designs, and it is remarkably precise and accurate, in my experience.
Old 19th November 2021, 02:35 PM   #9
Ah - Iím confused in that case.
Because the shape of the response in the acoustic power window does change when you adjust the max wattage and displacement parameters. And you can work this feature with only those two options engaged.
What is actually happening then?
Old 19th November 2021, 02:38 PM   #10
Ah yes thatís what I was thinking.
So Iím guessing hornresp assumes an infinitely hard and stiff pathway, with no crosstalk between the neighbouring folds?
And plywood will tend to absorb certain frequencies, as if said infinitely stiff pathway already had some absorbent material applied.
How good is Hornresp?Hide this!Advertise here!
Thread Tools
Whats a good hornresp input approximation for the "Karlsonator" ? freddi Subwoofers 1 29th July 2020 01:51 PM
is "closing off" a port in hornresp BP8P good 'nuff for comparing to BP6S? freddi Subwoofers 0 29th May 2019 11:18 PM
those good with hornresp - can this enclosure be kludged? freddi Subwoofers 6 22nd December 2011 06:00 AM
Isobaric horn + Hornresp Mr Evil Multi-Way 7 30th November 2004 10:33 PM
Hornresp help / JX150 316a Multi-Way 0 11th February 2004 04:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
