Sound System
Amplifier
  • Lab Gruppen
    Votes: 2 100.0%
  • Electrovoice
    Votes: 0 0.0%
  • Total voters
    2
  • Poll closed .
On the rear panel of the LAB there are 3 pushbutton switches right in the middle.
The left switch applies a 180deg phase shift to output B... make sure this is not on.
You probably do want to set it for parallel operations though, so the middle switch Link A-B should be on.
is left on normal, everything is left at 0 without low sum, everything is in phase ie tops plus subwoofers, this happens when I apply low sum , then I have to press the reverse button otherwise they are out of phase
cables XLR normal. the thing is that the ev boxes leave them fullrange and then I think that the frequencies overlap with low sum activated it s possible.
