Vented vs TL...
Vented vs TL...
Thread Tools
Old 10th June 2021, 01:08 PM   #21
martinsson is offline martinsson  Sweden
Technically it's a OD-MLTL
Right, and the mass loading stems from the ports air mass, correct?
Old 10th June 2021, 01:51 PM   #22
AllenB is offline AllenB  Australia
AllenB's Avatar
Vented vs TL...
Originally Posted by martinsson View Post
what designcriteras needs to met for calling it a TL,
Exploitation of box modes. A standard ported box doesn't do this.
Old 10th June 2021, 08:25 PM   #23
GM is offline GM  United States
GM's Avatar
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th June 2021, 08:30 PM   #24
GM's Avatar
Right, it must be a high enough aspect ratio for 1/4 WL pipe modes to damp the vent enough to make a measurable difference to a lower Fb, so varies based on desired tuning, otherwise it's presumed to have a ~uniform particle density.
Resonances of open air columns
Old 11th June 2021, 02:25 AM   #25
Brian Steele is offline Brian Steele  Grenada
Originally Posted by David McBean View Post
If you adjust for the end correction and set QL to lossless as shown in the attachments, the results become effectively identical, with the fundamental frequency being 42.4 Hz in each case.
Yup, but it does raise the question of which of those two models will more accurately predict the response of the attached system, without having to adjust any of the dimensions involved. I do know that the standard OD model did a very good job of predicting the Fb for both my POC6 and my "Boom Unit" builds.
How is the end correction calculated, btw?
www.diysubwoofers.org
Old 11th June 2021, 02:30 AM   #26
I forgot to mention that the inclusion of vent losses in the ODOV model probably makes its predictions of what happens to the FR around Fb a bit more accurate than the OD model.
Old 11th June 2021, 03:44 AM   #27
grindstone is offline grindstone  United States
grindstone's Avatar
dia = 2 * Sqrt(Ap / Pi) <---- Port tube diameter (m)
Lpt1 = Lpt + 0.306 * dia <---- Port tube length plus unflanged inlet end correction (m)
Old 11th June 2021, 06:26 AM   #28
David McBean is offline David McBean  Australia
The second (bass reflex) model will more accurately predict the results because it takes vented-box enclosure losses (default QL = 7) and the port tube internal end correction into account (the internal end of the port tube is assumed to be un-flanged).
www.hornresp.net
Old 11th June 2021, 06:41 AM   #29
Hornresp actually uses the following formula for the internal unflanged end correction length, which gives effectively the same result as the one above.
EC = 0.1952 * Pi * Rp
Where EC is the end correction length and Rp is the port tube radius.
In the previous example, Ap = 320.00 sq cm
EC = 0.1952 * Pi * Sqrt(320 / Pi) = 6.19 cm (to two decimal places)
www.hornresp.net
Old 11th June 2021, 07:49 AM   #30
Correct.
www.hornresp.net
Vented vs TL...Hide this!Advertise here!
Thread Tools
Dual-Chamber Vented Boxes BAM Multi-Way 9 2nd July 2004 01:37 PM
Vented box alignments Vg Multi-Way 7 26th May 2002 09:18 PM
QTS = closed or vented? dantwomey Multi-Way 6 15th March 2002 01:45 PM
Vented or TL pipo Multi-Way 7 7th November 2001 06:11 AM
Vented or TL pipo Multi-Way 2 7th November 2001 05:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
