Hi, I need some help, please.
I have two of these drivers. I can seem to calculate an ideal enclosure to make a sub with them.
I purchased these about 10 years ago, knowing what I know now, I wouldn't buy them again. From the response graph, they don't look like they go down low at all.
Woofer Speaker Driver - 10 Inch | Jaycar Electronics
Seems like a shame to chuck 'em in the bin, but am I just wasting my time with them?
Data in the attached .zip file
I'd appreciate any help or suggestions
I have these in ported enclosures ~32 litres tuned to about 40 Hz if I recall correctly. The bass is surprisingly good. The response forms a sort of shelf, so you can't just look at the -3 dB point from the midband. They are running in an active speaker crossed at 150 Hz so I have some leeway in setting the levels correctly. I know they look pretty bad on paper but I've had them since 2010 and haven't felt the need to change them out yet.
The actual measurements were a fair bit different to the specs, but didn't change the overall response much when entered into the calculator. Usable output down to 30-35 Hz.
What I found interesting with the published T/S specs in a classic alignment [Vas/1.44, Fb = Fs] I got the over-damped shadow line response, which allowing for my smaller ~15.1 L cab is similar enough to yours, yet when I used Mmd, BL and let HR calculate Fs, Qts it flips to a slightly under-damped one.
- Subwoofers
- Need help with two Jaycar CW-2198 subs
