Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#31 |
The cabinet wall vibrations are worse because they affect the fundamental.
Inside the cab the pressure is opposite to the radiated wave and the walls bend and radiate a wave that diminishes the fundamental, apart from resonances at higher frequencies. I had excellent results with spherical enclosures apri 050.jpg |
#32 |
Thanks for the link. Very interesting. And it gets at the question I've been trying to probe.
Is there a way, with readily available information, to determine when push-pull will yield enough benefit to warrant the extra complications? So far my answer has been that relevant information is often not available. Sound Integrity takes a stab (attached) but the Dayton Reference HO speakers are just described as "Triple shorting-ring motor for ultra-low distortion." And underlying all of it is the nagging question of audibility. Geddes and others have argued the importance of harmonic distortion is often exaggerated. I would think that if it's going to be an issue, then fundamentals in the bottom octave, with harmonics at frequencies we can hear better, is where it'll be most important. But I can't support that with data. No doubt it's out there. Too bad I have a day job demanding my attention! Anyway, thanks again for the posts. Few |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
what TS parameters to look at... to build compact sealed or ported subs | audfrknaveen | Subwoofers | 14 | 7th September 2019 09:24 PM |
:-( my (fe126en) FrugalHorn mk3 boxes sound wore than small boxes | Ensoniq | Full Range | 31 | 15th December 2015 10:25 PM |
(2) ScanSpeak 25W/8565 woofers, (4) HiVi D6.8 woofers, (2) Eton 7-373 Hex B woofers | Jimmy154 | Swap Meet | 14 | 11th July 2015 09:11 PM |
Fostex FF125WK Speaker Boxes / Planet 10 FF125WK Drivers/Boxes | jonparkhurst | Swap Meet | 2 | 23rd August 2013 06:19 PM |
compact sub - sealed or passive radiator? | Bill poster | Subwoofers | 5 | 8th June 2010 03:19 PM |
New To Site? | Need Help? |
