Advice sought: Woofers for compact sealed boxes
Thread Tools
Old 29th March 2021, 01:16 AM   #21
Few is offline Few  United States
Looks like an interesting construction approach! Glad to hear it worked out so well for you. Thanks for sharing it.
Iím aiming for small and inconspicuous, and flat response (as opposed to compensating for lower hearing sensitivity at low frequencies). My excursion-limited calculations suggest Iíll be able to get high enough SPL out of a small box if I donít run out of amplifier power first.
Old 5th April 2021, 03:25 AM   #22
I’ve been reading up on push-pull slot-loaded subwoofers. Has anyone seen distortion measurements on the Dayton Reference “high output” drivers? I’m trying to predict whether the push-pull driver arrangement would yield enough advantage to justify the extra enclosure size and complexity. A push-push arrangement would be easier to keep small and also simplify the force-cancelling assembly (just rigidly tie the magnets together). But if push-pull yields an audible improvement I would consider taking on the design challenge.
Few
Old 5th April 2021, 05:49 PM   #23
norman bates is offline norman bates  United States
norman bates's Avatar
All the shorting rings and stuff don't help below 100hz, compared to push pull.
PiSpeakers Forum - Push-pull versus shorting rings - Wayne Parham, June 21, 2006 at 16:18:33
Old 5th April 2021, 07:46 PM   #24
Thanks for the link! I'll do my homework--I hadn't seen that information before, and it seems highly relevant.
Old 5th April 2021, 09:48 PM   #25
Welcome.
I think the distortion reduction would have been higher if the drivers were closer together.
Old 6th April 2021, 01:30 AM   #26
Am I misreading the online reports? I’ve seen some showing relatively small distortion reductions from push-pull arrangements, and others showing a larger effect. Clearly it would make sense that drivers with symmetry issues would benefit most, but do the benefits scale simply with the magnitude of the second harmonic distortion? I could argue that such a correlation would make sense, but then things are rarely that simple.
Old 6th April 2021, 08:55 PM   #27
Digital Underground - Doowutchyalike (Official Music Video) - YouTube
Old 8th April 2021, 06:56 AM   #28
bansuri is offline bansuri  Italy
Yeah, I think the higher reduction is because they compare it with a single driver.
with balanced drive (wavecor) the speaker has little distortion.
the immense additional space and optics is difficult to justify.
Certainly the box vibration is reduced, a good weight can have the same effect
Old 8th April 2021, 02:42 PM   #29
Hi Bansuri,
Which case are you referring to? The audioroundtable.com link provided by Norman Bates indicates it's comparing dual woofers on a baffle to push-pull woofers on a baffle (figure attached). I'm probably misinterpreting your post. Apologies in advance.
In my post I had in mind post #758 on this thread. I've attached screenshots of the push-push and push-pull measurements compared there.
Few
File Type: png Screen Shot 2021-04-08 at 10.36.14 AM.png (181.7 KB, 69 views)
Old 9th April 2021, 04:19 AM   #30
Few. I refer to this white paper
https://www.wavecor.com/Balanced_Dri...ical_paper.pdf
With drivers designed like this there would be no improvement or very little
The posted measurements were of course made with a driver where the effect is extreme. Also it should be noted that the 5th and higher harmonics increased, may be because of the magnet and frame causing reflections.
Or rather the vent acting like a compression driver to the back
That is what the 758 says, I agree 100%
Advice sought: Woofers for compact sealed boxesHide this!Advertise here!
Thread Tools
what TS parameters to look at... to build compact sealed or ported subs audfrknaveen Subwoofers 14 7th September 2019 09:24 PM
:-( my (fe126en) FrugalHorn mk3 boxes sound wore than small boxes Ensoniq Full Range 31 15th December 2015 10:25 PM
(2) ScanSpeak 25W/8565 woofers, (4) HiVi D6.8 woofers, (2) Eton 7-373 Hex B woofers Jimmy154 Swap Meet 14 11th July 2015 09:11 PM
Fostex FF125WK Speaker Boxes / Planet 10 FF125WK Drivers/Boxes jonparkhurst Swap Meet 2 23rd August 2013 06:19 PM
compact sub - sealed or passive radiator? Bill poster Subwoofers 5 8th June 2010 03:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
