How about this...?
How about this...?
Thread Tools
Old 8th April 2021, 03:08 AM   #221
Din1990 is offline Din1990
Old 8th April 2021, 06:00 PM   #222
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by GM View Post
With such limited info, can't imagine this having any SQ anywhere near its 45 mm Xmax; Danley did it right using a synchronous motor/belt drive in his dual woofer/PR 14 Hz ServoDrive Contrabass subwoofer.
GM,
Most of the LF output of the SDL Contrabass came from the dual 18" passive radiators it used, each having 19mm Xmax.
The SDL Contrabass dual 15" had 9.5mm Xmax, impressive for the 1980's, but small in comparison to fairly commonplace subwoofers now.
If a rotary motor with belt drive were the only "right" or best way to provide linear excursion for a reasonable cost, Tom would have continued using the technology.
After standard moving coil transducers exceeded the SDL Xmax, and servo motors became more difficult and expensive to source, the approach was abandoned.
That said, the Contrabass output per size and power input still do not appear to have been improved upon.
Old 8th April 2021, 08:12 PM   #223
Booger weldz is offline Booger weldz  United States
Dayton Audio Ultimax18. Given 60 volts by the Dayton sa1000 amplifier?
1200 cm2 then 1200cm2 and then 400cm2, as 3 segments (two 180 degree immediate turns on centerline)
Driver at 0.349 offset in the split of the first fold, also the first fold location on acoustical centerline for air mass accumulatively as pressure node vs antinodes.
So it is as follows: 165.0cm ,155.0, 140.0cm. —> and 20.0cm after( tapped horn sim with L45 as 20cm).. that S4-s5 actual ‘area’, as 1200cm2 +,1200 cm2, plus 400cm2(no wood included) is 2800cm2. As its the far side of the cone. A rear chamber, But also centered as it can only fit and be perfectly simmed?
Impedance null at 12.4 hz, 90 degrees in phase is 26.8 hz(im in Wizard looking) , 7hz is the antinode in pressure ~120-140 hz is occuppied by both thd first fold and the last (as pressure (in length) is catching up to the sum as a wave form and harmonics.
Meanwhile stuffing was added and the first (L12 ) pipe at 3.349 kg and .23334 in segment number two(L23) and 1.2333 in L34. Noting the excursion never ever exceeds Xdamage through <10 hz in any amount of stuffing or varieties that still keep dB >100 at 10 hz and thus hypothetically a serious threat to 7.2 hz(sound as a weapon).
I ordered another Ultimax a few days ago and it arrives today.
What do you think? And,
Even then, we can confirm it in ‘PH1’ mode now, soon to be stuffed in next update as well? add an actual rear wall in phase from the point already established to enforce this ‘back wave’ we call ‘tapped’ entry and ensure its aware of itself or defining the ‘end of a wave verses a pipe? Whatever that means(?)
Old 8th April 2021, 08:36 PM   #224
I then move to PH mode. Ive made a 50cm rear chamber. And i no longer use stuffing... 12.8hz. I stuff the front and ‘mid’ pipe as before then its 11.2 hz. As impedance nulls in wizard, 103dB at 10hz showing, no way Xdamage is ever a threat now unless i put 6 hz in this somehow? Its all clear as it is at 10 when the plot ends before DC...? Phase is beautiful. 25 hz is the first time warp and 180/-180 is at 80 hz, 150 hz is a cycle to the moon, 200 back in orbit, 300 and i splashdown in the pacific but it was a weird reentry!?!? The eagle has LANDED?
The ups man better hurry. I need to go find more plywood, home depots out and real russian birch layers is 65 miles away in traffic to east of N san fransisco bay... eek.
Ive run out and have nothing in the 13 ply Furniture grade pine/poplar blend left Who wants a new ULTimax 15. Maybe ill do this with car audio cabin to join in? How retarded would that be!?!
Im going for another 18 instead if this sim is what it is.. and i have no doubts its somehow tainted with a lack of reality. But where at?
Old 10th April 2021, 03:07 AM   #225
Originally Posted by Booger weldz View Post
No! Guys, sorry, i know you wouldnt call me a retard , it is however a result of typing and not anyones fault
Here:
GMs approach to the bose wave cannon with DJM(rip) is also a shape you can create in a paraflex type C. While that might not seem like anything or if doesnt (?) it might not be.. but it is if it is and the same idea is in an od qw pipe from another location(upstream).
But start adding more driver so they spread as 3 would in the space of 3 in the width of 120cm. Then use That if you want to or dont. It only represents things if you want it to. Only 10 or 12” drivers fit. I use two or an 18 allone(it doesnt matter, its flooding the area of offset in one side. If an imaginery middle.
Thats all only going to make sense if you build it. Wjateveryou do look ata PH sim as if its 240 and 80 cm. Then offset in that in ways you can and will if youhave to use only 20/40 or 60 cm from a closed end. The driver might even force it actually... 20 as 12 is 36? And 40 and its 2 12s....side by side and 60 as its then 3 centered at 60...
Thats pressure phase and itll show you 160/80, 80 or 120/120.....80 itll even show you 120/120/100 and 20. (Plus offset as you must now use it on both sides) If not. Youre csa in pipe chunks is wrong. Or, your offset driver position sucks. The driver ts parameters suck. Youre idea sucks. But one of those sucks, not physics..
. its there anytime you wanna see it. But if you dont make it possible you wont even be able to sim it. It never sucks when phase is represented from both sides.
PH mode is a clear perfect visual to what wasnt before it existed. All that remains is Q losses and friction to heat. The perfect path is now known
Its not an algorythm its reality. Ignore it or flare it? Its only phase if you look at it straight in the face as a pipe through a pipe.
14.5hz all day in a sim. But its not just that. Itll be lower... pressure phase and distance thru a folded pipe are not the same. One has actually hit a wall to exist. The other is a bunch of ideas snd advanced centerline didnt help pressure phase? It cant... so why try?
Fb is more important? Sure. But this is not qw. This is pipe physics. Qw is what were using i suppose, but its gotta be shoved through a pipe and its folded. Period. Nothing can change that except of you ignore it. We have been, and i think we forgot?
I dont know much. But i dont have to. I really on other peoples ideas. Theres something in a pipe. Its pretty much obvious if its 3 pipes. And offset driver entry is weird??? Look at it. What is there? Look at it as 3 pipes. But theres a 4th its whatever is at the exit of those that meet in sound not length. So make known. ‘Path’ is not knowing...’TH’ and ‘PH’ have no ‘path’. Thats important. It really is
This: while abbreviated in many ways it still represents something at the harmonic of something the long one as a qw to the shared full wave they both define or represent parts of...
The green only depicts the length so its obvious what it is or that it needs to be in order to be ‘perfect’ . Its all very easy to confuse in a corner. Lets try not to comfuse anything, lets assume we are all wise and our collective wisdom will figure out some thing we all might find very intersting and mutually fun?
‘Perfect’ is the question? What is ‘perfect’ and we are going to assume the csa anywhere (as pipe segments shown ) at a turn or end and overall lengths are fair to Fs and Vas. As well as not put out of wack with any Qes/Qms(Qts) that might skew our Fb /Fs too extremes not inherint of the design (type C paraflex with 1, 2 or even 3 12” drivers and s2 as needed (on or two or three radius, 20,40,60cm assume) that then defines 40 cm everywhere(skip corners or skip trying to, i dont think i can feed any thing but optomism here. And the entire idea of a dual pipe attached at the end needs to help in doubt. I won't even waste a moment there. Ill keep building them and pretend i dont know anything? Its kinda hsrd after aWhile. The answer is ‘nobody cares how it works’, that voodoo is lucrative. And DIY is free love.
What do see? What do you think? What makes sense?
This shows how i have drawn it in a way that jumps ahead of itself by the same margin so its not confusing anything as a big single quarter of a wave shape (sine)on the main long path and its turns, yet needs to be flat and thrn just one swoosh of 4 it represents....
Just perused these replies at the free-time I got, wish you were nearby so that I'd learn some acoustics.
Back to the topic, "paraflex type-C" you described seems to be a simple build, I'd like it too, but does it really dig deep, Googled and it shows the typical "paraflex type-C" at most is tuned at 35hz, but I need to go deeper down to 20hz, can it?
I remember btw you've stated "HORN is a silly thought of a PIPE dream", then answer me now, below are a HORN and a PIPE, but design is the same, so which is the better (or you'd agree to)...???
Old 10th April 2021, 05:48 AM   #226
A horn doesnt exist. An expanding shape toward exit is not an impedance match until its entirely different looking and the mouth at those hz would be as big as the front if my house?
Silly words, but never the less, the pipe is entertaining realistic physics thats tight inside as soon as you put the pipe around the right part of a waveform thats parts fit in it, and/or after it in the pics . My drawings suck, but theres still a ckear picture of the idea and whats ‘needed’ in mist of them, even if outta scake?
File Type: jpeg CD8F97DD-2825-491C-AA57-3278177DFE10.jpeg (329.7 KB, 22 views)
Old 10th April 2021, 06:05 AM   #227
Just need lengths to get the right sum of phase vectors at the point they meet. If using pipe, you can use the pipe nodes and antinodes of a similar ((totally related in everyway thanks to harmonics or any length chosen in portions of as w model/sketch ) but its a smaller wave to show it or the cousin of it 3x as big or small.
That tends to be the same groupings in these things. Amd in reality you get multiples of 40/80/120/160 often (cm in a sim of parts). You might not know it, it might not be a straight pipe shape, but the paraflex holds this bd offset positions 100% everytime. The 2x 12 ‘cram’ type C, for example 40,120,80 and also 80cm on the other side of the driver. Thats all gotta dum at the imaginery point thats real. Draw it. iys a sine wave, so make it easy circles instead..
It work every time. In fact the last plain old qw pipe i just did for an rs265ho4 is ridiculously ‘perfect’ it seems, for what it is? I bought 3 more to try an ‘array pipe of sort or to spread 3 of a kind in a room with a 4th with identical geomtry in the ‘pipe’ ? No promises, only ideas. But talk isnt saw dust . And talk is con fusing. (Typing)... a paraflex is one thing. But its not the only thing yiu can do with the same idea. (Pipes, ones that coexist).
File Type: jpeg FB9AC625-D34C-449E-9F4B-8685CAF9EA98.jpeg (408.6 KB, 8 views)
Old 10th April 2021, 06:15 AM   #228
Youre totally right, the ‘paraflex’ wont go low. But nobody asked it to. Its just a couple pipes and a driver. its not a ‘ Paraflex’. Nothing is, everything is ‘physics’?
Im down to 10.2 hz in the ‘pair of pipes’ that uses the PH sim or TH.. and an 18” ultimax. moved the pipes around. Just to describe offset.... its not a ‘pair of flex.’ Words suck, typings worse... But you make good ideas, just find the driver to use them in!! Itll be whatever you want it to be
Old 10th April 2021, 06:19 AM   #229
Roar. Paraflex. Pipe and then another pipe. Its all good. Nothing but a plain qw pipe in that pick thithough. Not any length as the big section at exit thats useful (yet)
File Type: jpeg 2231EF51-3AF4-443B-BF09-96B7AE42F3A1.jpeg (24.4 KB, 5 views)
Old 10th April 2021, 04:00 PM   #230
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
I bet you could "C" up the piping to get rid of all those 180* turns.
Ol' Skool Hip Hop Basshead = Car Audio: Coustic Power Logic HT-612 in a BP4. Home Audio: Kicker 08S15L74 in a T-TQWT.
How about this...?Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
