What 18" driver would you choose for a dipole?
Thread Tools
Old 18th January 2021, 05:35 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default What 18" driver would you choose for a dipole?
Powered by say a Hypex FA501.
Around 300 Euro or less.
I've been eye'ing:
B&C 18TBX100 and RCF LF18G401
http://basaudio.wordpress.com
Old 18th January 2021, 05:42 PM   #2
ErikdeBest is offline ErikdeBest  Switzerland
Hi Bas!
What bandwidth do you want/need?
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 18th January 2021, 06:16 PM   #3
GM is offline GM  United States
GM's Avatar
With your moniker, the better question in my mind is: what driver would you choose for your app since an OB is the inverse of a bass horn?
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th January 2021, 06:27 PM   #4
CharlieLaub is offline CharlieLaub  United States
I've been eye'ing:
Have you considered the resonance frequency of this kind of enclosure? It's dependent on the depth of the cavities. An 18" will push the resonance down to around 150Hz. If the openings are small (like you have drawn them) compared to the depth the resonance will have an elevated Q (meaning peaky) and you typically have to cross over well below that, e.g. 80Hz.
The other concern is that if you use one 18" driver in this kind of setup there will be a lot of vibration. Better would be two 15s operating in opposite directions. Is there any particular reason why you want to use a single 18?
Anyway, if you were in the US I would recommend this driver:
IB3 Series - IB318 v2 | Fi Car Audio
I'm not sure how expensive shipping would be to your location, but it's probably not cheap. The driver does fit within your budget.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 18th January 2021, 08:29 PM   #5
Hi Erik,
They are to augment my open baffle Bastanis. (I have active sub 15" closed box) But I want to add the 18 inch dipole subs as Bastanis offers already. I just don't have the moolah to get the "official" units.
The current subs are set to a low pass 90Hz. So these will be similar.
Old 18th January 2021, 08:31 PM   #6
Basically because it is a proven concept for the bandwith it is aimed at. See pic of the dipoles Bastanis sells.
Basically what Bastanis designed them for. I made my baffles for the widebands a little wider...so 80Hz seems fine to me.
Old 18th January 2021, 08:37 PM   #7
I'm baffled by your question
Old 18th January 2021, 09:04 PM   #8
joensd is offline joensd  Germany
Looks like most constructions from Bastanis are ripoles.
Did you consider these:
SB Audience Bianco 18SW450 - first impressions (open baffle)
12-18" in the series and quite reasonably priced.
Old 18th January 2021, 09:14 PM   #9
Haven't heard of these. Will have a look.. Thanks.
Old 18th January 2021, 09:19 PM   #10
Mmm very interesting...
What 18&quot; driver would you choose for a dipole?Hide this!Advertise here!
Thread Tools
18" Dayton vs. 21" RCF - which one would you choose ? Vortex Subwoofers 7 12th May 2018 09:41 AM
Which Mark Audio driver/tube amp would you choose? rvsixer Full Range 43 28th October 2011 05:13 AM
What would you choose for Quad ESL-63, dipole or TL? tf1216 Planars & Exotics 19 14th June 2010 08:55 PM
What would you do with these 10 " woofers if you would be me ? kanaddict Multi-Way 31 7th February 2003 12:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
