So can I make a 1x2x4' bass horn? Or not really?
Thread Tools
Old 14th January 2021, 11:19 AM   #11
Booger weldz is offline Booger weldz  United States
Originally Posted by GM View Post
1x4 = 10'
~1129/10 = ~113 Hz
Setting on and perpendicular to the floor [2pi] = ~0.707x = ~80 Hz
Solid/massive wall [1pi] = ~0.707x [full octave] = ~56 Hz
Path-length, throat area, room modes will set the amount/amplitude of ripple, ultimate usable low corner F.
200cm2, 400cm2, 800cm2, 1600cm2, at 120 cm increments? And split at 360cm by a tapped driver entry? Substitute 120cm for 80 cm if needed at two points? And put the driver at 200cm/0cm start middle whatever you wanna call it...tapped ...split. Now shrink the CSA used in each to a-lesser and lesser area, and i start to see a happy median? Yet i get confused because theres a fold in those all thats not represented and if its a 180 turn each time its a 50/50 LP filter for each as upstream frequncues? Am i to guess? or can i guess? i can see offset driver works in the same way... but im
Not offsetting a driver im dividing its entry. Something seems to work here and if i cant sim the folds i cant see the idea i can barely create experimenting with lots of pvc pipe parts over and over
Old 14th January 2021, 04:33 PM   #12
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by head_unit View Post
By ported horn do you mean where the rear chamber is ported?
In the next sentence in post #7, I wrote "the ported cabinet...", just forgot to write that in the sentence you quoted.
That said, a “V” (slot) loaded driver in a ported cabinet could be thought of as including some degree of "horn loading".
Old 14th January 2021, 04:43 PM   #13
weltersys's Avatar
Originally Posted by Booger weldz View Post
1)Is there a good drawing of this?
2)I think ive been chasing this idea and by adding the tap at 3/4 down ive confused it into something its not?
3)Is it the sim or is it the segmental distances?
4)One is harmonic intervals inside the folded lengths?
1) The photos of the actual construction template drawings in the "Lab 12 Domino DFLH" thread are the only ones made.
I don't understand your questions 2, 3 and 4.
Art
Old 15th January 2021, 10:54 PM   #14
zobsky is offline zobsky  United States
zobsky's Avatar
the picowrecker tapped horn is about that size
Lilmike's Picowrecker | AVS Forum
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 18th January 2021, 02:42 AM   #15
Art
Im always trying to fold on harmonic intervals and sneak that into pipe segment expansions in the ‘horn response’ sim that doesnt show a fold but hints at a variety of things and one im particular to has always been a sort of keystone layout shape, though its skewed for the 12” driver i typically use because its motorforce is cheap and expendable... it models in ‘pairs’ like a 18ds115 single will, but i shrink the throat area CSA or add damping in anyway/many ways to fill in the slight differences otherwise usually. i wasnt sure if that was part of this design and couldnt see the pics clearly, or tge outlines on the plywood
Old 18th January 2021, 04:21 PM   #16
weltersys's Avatar
Folding on "harmonic intervals" in the Keystone TH, the Domino DFLH, or any other horns I have created has not been part of their design process.
Art
  Reply to this post
So can I make a 1x2x4' bass horn? Or not really?Hide this!Advertise here!
Thread Tools
Really, really large subwoofer horn dragospk01 Subwoofers 8 1st August 2015 11:30 PM
Can someone check over my HF horn design to make sure I'm not crazy? dragospk01 Multi-Way 40 25th April 2015 07:15 PM
so I can make new thread ,but can't make any kind of reply? geargeeksp Forum Problems 3 8th November 2014 03:56 AM
Can I make a really simplistic line-level signal go mono one way, stereo in parallel? Nazo Analog Line Level 8 28th August 2013 03:35 AM
Attn: GM Not really an MLTL and not really a BR home for a 167e loninappleton Full Range 7 20th April 2010 04:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
