Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
I currently have the Dayton 8" reference sub in their sealed enclosure and am thinking of adding a second sub. I really like the sound of the dayton and even with just a 100 watt amp it goes plenty loud for my music listening levels.
I don't have enough room to add a second of the same and I've read that it isn't good to mix sealed and vented subs. Is there a problem mixing different sealed subs? I was looking at either LS10-44, or W8-2282 in a small sealed enclosure. |
#2 |
Maybe someone smarter than me can tell you if this crudely calculated phase graph means they would sound fine together. (I don't know how many degrees difference it takes to cause a problem, just that 180 is completely out of phase IE total cancellation, and I'm pretty sure drifting phase is the reason for the usual recommendation against mixing sealed and ported playing the same range). I only modelled the slim 10.
bottom line, highlighted: RSS210HO-4 in .75ft3 next up, LS10-44 in .75ft3 top line, LS10-44 in .33ft3 Max phase difference between dayton and LS10 in equal volumes is ~20 degrees. Max between dayton and LS10 in .33ft3 is about 45 degrees. |
#3 |
It's never good to mix two different drivers in the same passband, so no, it's not a good id.
#4 |
thank you for the information, it was very helpful.
#5 | |
At 45 degree phase difference, the loss in level compared to two perfectly "in phase" (0 degree phase shift) sources is less than one dB. In other words, if phase response is within 1/4 wavelength, output is nearly the same as two identical sources which sum to +6 dB. Small room modal response can easily result in variations of over 12dB between various room positions, making the small difference level due to +/- 45 degree phase differences between two sealed subwoofers looks quite small. Good information here: Merlijn van Veen - Displacement is Key Art Last edited by weltersys; 4th December 2020 at 07:14 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Dayton DCS205-4 for small sealed sub? | Howard | Subwoofers | 14 | 1st December 2017 08:07 AM |
Suggestion for beginner build of small sealed musical sub? | Mistertaz | Subwoofers | 26 | 4th February 2015 02:05 PM |
Input on these two drivers for a small sealed sub? | peace brainerd | Subwoofers | 9 | 23rd November 2012 05:43 PM |
servo sub for small sealed box? | autopi | Subwoofers | 3 | 12th April 2008 04:49 PM |
Small, Sealed Box for Sub; Linkwitz Transform Circuit | wrestlinguy | Parts | 11 | 25th August 2003 09:19 PM |
New To Site? | Need Help? |
