Repurpose a Logitech subwoofer driver
Thread Tools
Old 25th November 2020, 06:34 PM   #1
trumper is offline trumper  Canada
Default Repurpose a Logitech subwoofer driver
The Logitech z623 system came to an end when the control pod switches started to not work properly. Tried to fix but nope.......crushed more surface mount components than able to replace.
Sooooo... the subwoofer was more than my listening room could use (at reasonable levels) and there is a bad room resonance around 60hz.
So I removed the sub driver from the cabinet and set about to build a replacement cabinet with new class D amplification.
Progress reports to follow.....
Old 27th November 2020, 09:56 PM   #2
The goal is augment my mMar-Kel70s. I will be happy with 40hz which the original sub could do.
With no parameters for the driver, I decided to use the basic volume of the original box - about 17.4 litres or 0.614 cu ft. I also wanted to use a slot port instead of the original round port.
I found a port calculator image on this forum but can't remember which thread so I will post the image here.
After making an excel sheet to do the math, I have drawn the plan.
File Type: jpg effective Port length calculations.JPG (132.3 KB, 145 views)
Old 27th November 2020, 10:22 PM   #3
waxx is offline waxx  Belgium
It's not that simple, as there are no published specs of the driver you (or someone) need to measure it to get the specs. Only from the specs you can determine the right cabinet for it. Search someone who can measure the driver (or if you have Dats or Clio or so, do it yourself) and start from there from scratch. Now you're shooting in the dark.
Old 27th November 2020, 11:35 PM   #4
REDSKIN is offline REDSKIN  England
Why do you need ts parameters if you're making a box the same size as the old one?
He shoots. He scores!
Old 28th November 2020, 10:06 AM   #5
I know that this method is not ideal without driver specs but I figure that the original box was designed for the driver so we shall see how close this "dead reckoning" approach gets me. If nothing else, it is fun to make the excel formulas and then play with the variables to see the calculated outcome....
The original box was 1/2" mdf and this one is 18mm baltic birch.
Old 28th November 2020, 10:36 AM   #6
Well, a round port reacts different than a slot, so it needs an other length than a slot. What will hapen is that the tuning of the port is not right. Box size could also not be ideal as commercial speakers are more build on size and looks than on specs, especially this kind of speakers. But you could try off course...
Old 1st January 2021, 07:35 PM   #7
Well it is together....but there is no bass. Driver isn't moving with 50hz signal and barely moving with 60hz.
I suspect the amp needs some modding as per John Audio Tech (TPA3116 audio amplifer board test, review & mod - YouTube).
Old 2nd January 2021, 12:22 PM   #8
Surtsey is offline Surtsey  United Kingdom
By sealing the port do you get more or less bass?
Old 9th January 2021, 04:06 PM   #9
Finally got around to sealing the port today. No real difference.
However I moved the sub and i can hear the 50 - 40hz tones (although reduced level).
I will try bypassing the amp's 5532 preamp with a capacitor once i source one.
  Reply to this post
Repurpose a Logitech subwoofer driverHide this!Advertise here!
Thread Tools
Logitech z-2300 and logitech z4 pod Hammerfreak Subwoofers 6 1st September 2018 02:38 PM
Repurpose SS stereo transformer/power supply in a guitar amp mefergus Instruments and Amps 11 4th September 2015 07:17 PM
Repurpose an X-BoSoZ PSU still4given Power Supplies 3 15th April 2014 02:42 PM
Which industrial transformer to repurpose? ozerik Power Supplies 3 28th December 2010 01:34 PM
repurpose wall wart a good idea? gary h Power Supplies 8 11th January 2010 07:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
