CNC services
CNC services
Old 3rd September 2020, 01:42 PM   #1
NiToNi is offline NiToNi  United Kingdom
Default CNC services
Could you recommend someone in Europe who could CNC all the pieces of my own subwoofer design (Solidworks) without it costing an arm and a leg? It's a one-off custom project for my own HT.
It’s a pretty serious piece requiring a few advanced cuts, going by what a few friends ‘in-the-know’ have told me, so I don’t know what kind of machine is required - although in my world, it’s basically just a “simple box” with no rocket science involved. But OK, the bracing is pretty brutal, so if Apollo 13 had been as structurally sound they would probably never have had their “Houston, we have a problem” moment… 😉
Here’s a link to the design (HTML eDrawings). Use right-click for options like removing or isolating pieces:
Subwoofer_assSplit_200617.html
I’m open to suggestions from anywhere in EU or the UK as long as the cost is competitive to justify the shipping cost.
Old 4th September 2020, 02:35 PM   #2
epa is offline epa  Netherlands
i could do it for you
you could make the cam yourself in sw.
saves some time .
btw i,m located in amsterdam
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 4th September 2020, 04:08 PM   #3
Thanks, PM sent.
Old 4th September 2020, 05:30 PM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Hey, that´s some seriously stiff/rigid structure!!!
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 4th September 2020, 06:03 PM   #5
joda is offline joda  Italy
Try here
Benvenuto/a su Il mio pannello
regards
Old 4th September 2020, 11:53 PM   #6
Thanks. Hopefully it will pay off.
Originally Posted by joda View Post
Try here
regards
Thanks. Have sent them an email but a bit confusing when there is no option to view their website in English. Would be a natural fit though since the enclosure will be hosting Italian drivers
Old 5th September 2020, 09:30 AM   #7
Originally Posted by NiToNi View Post
Thanks, PM sent.
pm responded
. hr driver db
Old 5th September 2020, 10:26 PM   #8
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
I don't think the design is particularly complex. If you cut the 'triangular' braces the same size as the front and back panels you end up with mostly squarish brace panels with 4 windows cut in each. It would be fairly easy to design this to make the square brace panels the same size and make a template to route them from. (I'd probably rough cut with a jigsaw and finish with router)
Don't know if you have a tablesaw but if yes that would make it even easier.
Rob.
Way back when I had access to a laser cutter I built these midbass boxes. I think I could do them by hand now, just takes more time..
Old 5th September 2020, 11:24 PM   #9
LinuksGuru is offline LinuksGuru  Europe
3-axis CNC router probably enough if you make angled vertical cuts and chamfers manually out of a flat surface. 5-axis router services are horribly expensive.
Old 6th September 2020, 11:13 AM   #10
Rob.
Thanks, Rob. Those boxes are beauties
I've had help doing the 3D CAD and there's not really any flexibility in changing the design from this point onwards tbh. Sure, the roundovers on the bracing windows aren't necessary, acoustically or optically, but were more an OCD thing (of the variety we all suffer...) and I guess there might be some other features that could be left out if just a PITA.
CNC servicesHide this!Advertise here!
PCB Design Services prasi Vendor's Bazaar 0 28th March 2020 08:28 AM
What do services normally run? bacon665 Planet 10 hifi 4 8th January 2011 12:47 AM
USA remailer services mobyd Everything Else 2 20th January 2006 12:43 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
