Hi benceg,
You have 40 and 400 usd drivers. Is that a problem for you, also what market (US, EU or overseas?) are you. Do you have manufacturers and/or any models of choice? The use you are giving to it, easy listening, HT, PA or other.
Vb = 80L net (internal)
Port: What dimensions do you have that can be simulated (int. diameter or area/length)?
Can you post a picture.
Yeah sorry. A litlle correction. The budget would be around max. 300-350 USD, but I'm also interested and looking for second hand market and I'm in the EU!
So far someone recommended me the "LOUDSPEAKER 12""LX60V2 8 OH", but I'm don't know, it's more of a woofer than a subwoofer driver, am I right ? The 49Hz fs is a bit high ? Although the spec says it goes down for 35 Hz.
I looked at the Faital pro too, is there a recommendations from them?
It's for PA use but only in small bars, pubs, garden etc. at the moment the amp is the lowest part of the system(the sub part cuts at around 120 Hz), but that will be changed in the future. It's a 2.1 setup. The top speakers are a pair of custom built (20l internal) box with Beyma 8G40 for the mid/woofer and CP380 high.
The port inner diameter is d=10 cm, but length can be adjusted for the optimal tune.
Hi benceg,
So far I found these, but i'd like hear other brands and opinions as well.
SOVEREIGN PRO 12-500
FaitalPRO | LF Loudspeakers | 12FH510
FaitalPRO | LF Loudspeakers | 12PR320
Hi!
I'd like to hear your suggestions for a 12 inch woofer. I have an 80 L vented box and I'd like to achieve the low end at least 40-45 Hz. Also imprtatnt that the speaker is sensitive, around 93-5 dB or more.
Thanks!
Fane 12-500wrms.
Fane : Fane Sovereign 12-500LF :: PS72.77
- Subwoofers
- 12 inch sub driver recommend
