New plate amp problems
Old 23rd March 2020, 03:44 PM   #1
winggo is offline winggo  United States
Default New plate amp problems
A number of years ago I built a subwoofer using the Peerless 12" xls long throw woofer with matching passive radiator. I put a kg-5230 300 watt plate amp in that I bought from Madisound. The subwoofer work wonderfully for many years when a couple of weeks ago the amp gave out. I bought a SPA500 amp from Parts Express with 500 watts and installed it last week end. At 75% gain this amp is just audible. At that kind of gain my old amp would have broken windows. I've got a email into Parts Express about the problem but haven't heard back yet. Changing all the setting does not do much for the volume. Am I doing something wrong or is the amp possibly bad?
Any suggestions on how I can test this amp to see if it's bad or not?
Old 23rd March 2020, 04:43 PM   #2
Brian Steele is offline Brian Steele  Grenada
"At 75% gain this amp is just audible"
Maybe the issue is with the source. Try using another source to drive the amp.
www.diysubwoofers.org
Old 23rd March 2020, 06:35 PM   #3
zerokelvin99 is offline zerokelvin99  United Kingdom
Try different source, interconnects, LFE only input, check all rear controls inc. Lowpass
Old 24th March 2020, 04:45 AM   #4
SamAnytime is offline SamAnytime  India
From the manual:
1.) Left/Right inputsRCA style jacks that will accept standard line level inputs from a pre-amp level source. They will accept a stereo signal and internally combine it into mono. Both left and right input jacks must be connected to the source in order to drive the amplifier to full output. The use of a “Y” cord is suggested if a mono source is all that is available.
Old 25th March 2020, 01:54 PM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Had a similar issue with a different brand sub amp and the amp was faulty so was returned. Checked it against a low power Class D amp as a sanity check and that provided heaps of volume.
You don't say the source or whether you are using the Stereo or LFE inputs.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 25th March 2020, 03:28 PM   #6
Turns out is seems to be a problem with my Jolida inegrated amp variable outputs. I hooked up to the outputs on my head phone amp and got plenty of volume. Looks like I need to get Jolida amp in for repair.
New plate amp problemsHide this!Advertise here!
How to determine plate-plate resistance for push-pull? flysig Instruments and Amps 52 10th January 2018 10:09 PM
CNC custom aluminum plate, case, heatsink, front plate SunnyCNC engineering Vendor's Bazaar 0 16th September 2017 02:27 AM
Center-tapped Plate Choke vs. OPT for PP plate loads rongon Tubes / Valves 10 20th February 2017 12:05 AM
Simplified pentode Loftin-White with plate-plate feedback homeskillet Tubes / Valves 17 3rd August 2013 04:58 AM
Titan A-200 plate amp problems Andysl1200 Subwoofers 1 1st May 2007 07:47 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
