Xmax
ICG
Disabled Account
Joined 2007
To chose a driver for a subwoofer, you have to have a look at how the manufacturer calculates the maximum excursion. Since the most manufacturers use a different calculation, you'll be much better off to use the purely mathematical calculation to chose a driver which is
(winding heigth - pole plate depth)/2
Since the human ear isn't very susceptible to distortion in the bass/sub-bass range, the actual usable excursion is a lot higher, it's still the most objective way to compare the excursion of drivers since most of the manufacturers got their own way to 'calculate' the maximum excursion.
That TH design is 119 liters net (that's big for one 8" driver) and has a passband output at looks to be only 3dB or so more than the output of my "Boom Unit", which is a TL designed around that same driver, that takes up 26 l net and has a wider usable bandwidth with no 10dB out of band peaks to deal with. The "Boom Unit" serves as my multimedia subwoofer.
For HT use, if I had that amount of space available for my use, I'd go for a vented or TL design based on a larger driver, for more linear output capability.
I do have room for a pair of -4cuft (115L) enclosures. I just don’t think I’ll get a pair of VBSS or Marty’s past my wife.
I’m open to suggestions for proven existing designs using lower cost drivers. Not too much over US$100 each preferably. Our currency is shot to bits at the moment.. Plywood and my time is cheap. A second hand Behringer dsp amp isn’t too hard to find either.
What about a pair of UM12-22 12", recommended box is
Vented 4.0 cubic ft. (net internal, not including driver or port volume) tuned to 20 Hz with a 10" wide by 1.5" high slot port that is 25" long, which yields an f3 of 19 Hz
They seem to fit the bill
Out of interest. How far off a flat response is it ok to go before it’s noticeable? See attached. I reduced the box volume by about 20 litres and the simulated response rose by less than one decibel.
Have you seen WES has a new catalogue out, on SB Acoustics PA style drivers, there heaps of subs but being PA big boxes
What about a quintet of DA's SD270A-88 10" DVC Subwoofer 4 Ohm in sealed boxes about 33ltrs, one in each corner and still give you a 4 Ohm load... and a whole $115 ea!
