Best Subwoofer Driver Under 0
Old 13th March 2020, 10:30 PM   #1
Tazzo1 is offline Tazzo1  United Kingdom
Default Best Subwoofer Driver Under $400
Thinking of having a sub custom built for me and I will be most likely be using a SAM 300D amplifier. Any suggestions for a driver and anyone with the experience of the following?
Volt 2500.1
Volt B2549
Volt 250.8
Seas L26ROY
Morel UW 1058
Scanspeak 23W/4557T02
Old 14th March 2020, 12:31 AM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
The driver with alignments for the specs below is the more adequate for the power amp you have.
Power rating at 4 Ω 300 W
Power rating at 8 Ω 150 W
Note: you have both 4 and 8 Ω drivers. Needs to check power with excursion @Xmax.
Dj ''S'' - NYC Classics (Mix)
Old 14th March 2020, 12:38 AM   #3
At 8 ohms and a sensitivity of 85db, would it go loud enough? My room is about 3m X 3m
Old 14th March 2020, 12:47 AM   #4
Inductor's Avatar
Volt B250.8 is adequated and Morel is nice but needs more power.
Volt B2549 also needs more power from the amp but they model well enough.
Old 14th March 2020, 01:03 PM   #5
Old 14th March 2020, 07:52 PM   #6
waxx is offline waxx  Belgium
Not on your list, but my favorite subwoofer of the moment is SB Acoustics SB34NRX75-6. It works very well (and very low) in large sealed subs. A 77L selaed gives you (without eq) an F6 of 30Hz and an FS of 23Hz. If you need it lower, you can go to 150L and get an F6 of 29.5Hz and an FS just below 20Hz. It will easely fill your room (and overpower it) with that amp as it's 88dB on 2.83v/1m efficient in that setup. You can also put it in a vented box wich will go lower (in a 250L vented an F3 of 19 and an FS of 14Hz) and louder (90dB efficient).
My own actual sub is also a 77L box, but with the Scanspeak 26W/8534G00 driver, and that goes with an F6 of 32Hz and an FS of 24Hz, and is only 1.5dB less efficient. I did build this before i knew about the SB driver. I did build the 77L cabinet with the SB driver for a friend who listens to dub and is a bassplayer and requires a very deep and powerfull and defined bass. He loves it totally...
If that is too big, Dayton Audio makes drivers that can get that low in smaller boxes (i don't know the type by heart) and those are also great. Parts Express even have a flat pack for one of their drivers that work very well...
Old 14th March 2020, 08:06 PM   #7
I emailed Falcon Accoustics and they recommend the Seas driver on my list, I might just go with that.
Best Subwoofer Driver Under 0Hide this!Advertise here!
200W driver Vs 600W driver - subwoofer performance audfrknaveen Subwoofers 12 6th September 2019 06:41 PM
Subwoofer driver advice needed: 10" - 12" driver for 88L (3.1CuFt) enclosure ctmorsejr Subwoofers 11 23rd May 2016 04:03 PM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer driver up to 400 USD esl Subwoofers 7 29th February 2004 05:05 PM
Subwoofer driver griff Subwoofers 2 28th December 2001 04:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
