Sound Cuts Out - Low sound causes it to cut out
Old 13th March 2020, 01:47 AM   #1
rl33515 is offline rl33515
Default Sound Cuts Out - Low sound causes it to cut out
Hi there,
When movies have a quiet scene - the sound from the soundbar cuts in and out. Does anyone PLEASE have a fix?
We maximise the laptop/chromecast volume, then control the soundbar volume from there.
I have a TV - Chromecast 3 HDMI plugged in - and the below sound bar connected to the TV with an optical cable.
Panasonic 200W 2.1 Soundbar w/ Wireless Subwoofer
SC-HTB488GNK
The TV is quite old - Panasonic TH-P42S10A.
Old 13th March 2020, 02:29 AM   #2
6L6 is online now 6L6  United States
6L6's Avatar
Does the sound bar volume change with the TV remote control?
Old 13th March 2020, 03:42 AM   #3
Thanks so much for the reply!
No - there is a TV volume, and a Soundbar Volume. each device has their own remote.
If I turn up the TV volume with the TV remote control, as well as the sound bar - there's a weird double sound as both the TV and the sound bar are producing sound. So I leave the TV on Zero.
Thanks!
Old 13th March 2020, 06:59 AM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
If possible, try connecting by HDMI ARC on the TV if it has it.
If there is no signal a lot of devices mute so have a look at the digital out settings on the TV as there may be a setting that's causing issues or mute. Also look at the setting in the soundbar.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 13th March 2020, 04:46 PM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
+1 on Rabbitz's post.
Chris
Old 13th March 2020, 10:10 PM   #6
turk 182 is online now turk 182  Canada
if it's nothing digital could leaky input coupling caps be at fault...??
Sound Cuts Out - Low sound causes it to cut outHide this!Advertise here!
Sundown NS-1 sound cuts out at high volume - No protect Troy Dionne Car Audio 4 30th April 2017 02:47 PM
Marantz MA500 Amp--sound cuts in and out above 25% volume, followed by blown fuse telekinetic Solid State 1 25th October 2016 05:38 PM
Martin Logan Aerius i -- no sound, cuts in/out daspek Planars & Exotics 3 19th September 2016 02:34 PM
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver tiefbassuebertr Digital Source 145 25th April 2011 07:39 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
