How to build a sub that can go down to 20hz or even 15Hz??
Old 6th December 2019, 07:07 AM   #21
David McBean is offline David McBean  Australia
Originally Posted by Circlomanen View Post
Here is the Hornresp input data if someone wants to play with this idea or make a drawing.
What I would really like to know is how you managed to get a value of 1.4908850 to appear in the disabled Fta text box. It should be 0,00 :-).
www.hornresp.net
Old 6th December 2019, 05:58 PM   #22
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Default What is the Frame Diameter
Originally Posted by bjorno View Post
Hi wonderfulaudio,All
You're correct.Without doing a Consistency Check and an educated guestimated calculation of Driver Sd and Xmax from a Ruler Measurement of the Driver Frame Width and the Rubber Surround Diameter) : The given Data could be way off and sculptured to impress any ignorant Layman.
So What is the Frame Diameter?
b
Hi audfrknaveen,All
No Help Posted hereinafter/above but my Fingers are crossed(Sd and x max is probably both stretched...) and continuing being back on Topic! Pictures may Help:
b
File Type: jpg 2x Iwai_12inch-4Ohm_xmax=12mm_T-TQWT.JPG (901.9 KB, 91 views)
Old 6th December 2019, 06:19 PM   #23
Fwiw: Adding HR Input Text:
b
Old 6th December 2019, 06:28 PM   #24
Discopete is offline Discopete  Canada
Originally Posted by audfrknaveen View Post
I saw this thread.
15HZ Sub (you can build in an hour)
But unfortunately the images are not opening. It's a very old thread. Anybody knows the design ??
Check out Rod Elliott's site #48 and 71...subwoofer control, etc.
sound-au.com
Looks like the link won't work. Just google Rod Elliott Sound and it will take you there.
Old Yesterday, 09:25 AM   #25
Circlomanen is offline Circlomanen  Sweden
I don't know, but I suspect that running Hornresp in Proton (Steam windows compatibility layer) might be the cause.
Proton (compatibility layer) - Wikipedia
GitHub - ValveSoftware/Proton: Compatibility tool for Steam Play based on Wine and additional components
We live in a horizontal world, why use vertical topologies???
Old Yesterday, 12:18 PM   #26
I guess that probably doesn't help things much... :-).
It is still quite weird though, how it managed to generate a value out of nothing, and use a period rather than a comma as the decimal separator :-).
www.hornresp.net
How to build a sub that can go down to 20hz or even 15Hz??Hide this!Advertise here!
15hz, high volume Etocynned Subwoofers 51 24th April 2019 12:40 PM
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 83 23rd July 2017 11:06 PM
Easy-to-Build 20Hz Subwoofers for Medium Size Room techbiker Subwoofers 28 5th February 2015 01:49 PM
15HZ Sub (you can build in an hour) Patrick Bateman Subwoofers 30 16th May 2007 05:30 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 03:54 AM
Copyright ©1999-2019 diyAudio
