Isobaric sub based on Pyle PLPW15d
Old 7th October 2020, 07:15 PM   #11
kipman725 is offline kipman725  United Kingdom
Overly Enthusiastic
kipman725's Avatar
Isobaric sub based on Pyle PLPW15d Send a message via MSN to kipman725
Hornresp record (with pyle driver) and sketchup 2017 model of the box attached. Also did a quick sim with a single RCF driver and it looks fine. Voltages are 2.83V on the RCF and 4V on the Pyle for standard 1W/1M. Even with this the single RCF driver is more sensitive than the isobaric pair of pyle drivers.
Old 9th October 2020, 05:57 PM   #12
sharres is offline sharres  Austria
thanks for the informative answer.
sketchup would be much appreciated
so many intresting designs out there, and such a hard decision which one to build.
yeah the pa will be my winter project, lets hope that next year all those sad speakers in lockdown, will get more more playtime
best
sergej
Old 16th October 2020, 04:38 AM   #13
gp4Jesus is offline gp4Jesus  United States
Very interested to see the final result.
Any warnings? I’ve considered this alignment w/a different driver in a smaller closure for HT use
Thanks tony
Old 16th October 2020, 11:56 AM   #14
Overly Enthusiastic
kipman725's Avatar
It mostly behaves as a ported box with a bit more output in the upper bass, the isobaric mounting is to overcome the weak motor force of the car audio drivers. So beyond the usual considerations of ported boxes no warnings needed.
Old 17th October 2020, 10:12 PM   #15
Booger weldz is offline Booger weldz  United States
I have something similar, I simmed it as a single on the right in BP parallel6, and the isobaric on the left using compound horn. I have both at Xmax (off by one a tiny bit favoring the isobaric input power on accident...).
It seems consistent with the assumption the amp will allow the parallel wiring of the isobaric?
  Reply to this post
Isobaric sub based on Pyle PLPW15dHide this!Advertise here!
Pyle plpw15d 87pontiac Subwoofers 20 17th June 2019 10:53 PM
Project for Pyle PLPW15D driver mariadumitruiulian Subwoofers 20 14th March 2019 04:26 PM
Pyle Power Capacitor, Pyle of what? Perplexed1ne Power Supplies 23 14th January 2011 11:29 AM
Pyle Qcura Multi-Way 0 2nd August 2002 10:27 AM
Pyle Pro Qcura Multi-Way 0 9th June 2002 02:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
