Goldwood  GW-215/4 OB sub-woofer?
Old 21st November 2019, 09:38 AM   #1
Giri is offline Giri
Default Goldwood GW-215/4 OB sub-woofer?
I simulated a four Goldwood GW-215/4 with four 15" driver per side, in a series-parallel configuration, in Basta. I have attached are the pictures of the simulation.
1) Is the xmax of 3.5mm a matter of concern? What is the xlim of Goldwood GW-215/4?
2) Please let know any observations or comments on the design, its feasibility, improvements etc.
Old 21st November 2019, 12:31 PM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
How loud do you want to go?
OB bass is very lossy, but does have some advantages with regards to room interaction.
I wouldn't worry about Xmax so much as how gracefully the driver approaches and exceeds Xmax.
Chris
My work: www.grimshawaudio.com
Old 21st November 2019, 02:02 PM   #3
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yes, slightly less big box interaction, much less small box interaction
Old 22nd November 2019, 02:33 AM   #4
Chris
I am worried about damaging the driver at volumes that cross the xlim more than any distortion
Old 22nd November 2019, 06:34 AM   #5
More like zero small box interaction
Old 22nd November 2019, 08:36 AM   #6
chris661's Avatar
Fair enough. That does come back to my question, though - how loud do you want to go?
You might find it's impossible to hit Xlim - it's rare to find a driver that will actually let you bottom it out as most tend to run out of motor force towards the ends of excursions, plus the surround/suspension is starting to lock up. The result is that the cone simply won't go any further, no matter how much power you drop in.
Chris
Old 22nd November 2019, 11:22 AM   #7
Chris
I have seen internet pictures of some cones broken due to cone exertion beyond limits. Hence, the concern.
Old 22nd November 2019, 02:17 PM   #8
chris661's Avatar
That's almost certainly down to PA usage. In a HiFi situation, if it sounds bad you'll turn it down. In a PA situation, you want every last bit of output and treat the speakers accordingly.
Chris
Old 22nd November 2019, 02:24 PM   #9
You could lower the excursion requirements by using an H or U frame
Old 22nd November 2019, 03:10 PM   #10
I'm considering a H-frame or a V-Frame
Goldwood  GW-215/4 OB sub-woofer?Hide this!Advertise here!
need help with .frd and .zma for goldwood gw12/8 silver flute 5.5 woofer noahtheviking Multi-Way 3 28th January 2019 09:07 PM
Goldwood GW-12PC-8 12" Heavy Duty Woofer 8 Ohm sewerwisp Multi-Way 0 24th April 2017 09:20 PM
MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame Jim Shearer Full Range 608 21st October 2014 03:09 PM
Goldwood 1858 OB 2-Way - Vocals in woofer? mortron Multi-Way 6 13th May 2013 06:36 AM
Open Baffle Woofer for less.. Goldwood GW-1858 ScottG Full Range 3 6th February 2011 11:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
