6th Order Sub
6th Order Sub
Old 16th November 2019, 03:18 PM   #11
paulys55 is offline paulys55  United States
Originally Posted by gigigirl View Post
Don't know why more people do not use the cabinet design.
Cheers
Well, it comes down to intended use. If you can trade wider bandwidth for higher output in a narrower bandwidth you build a bandpass enclosure. Also, typically the volume is larger than some can tolerate. The box is more complex and needs to be more precise with regards to volume and port dimentions. Basically, it's easier to throw a sub in a sealed box, eq it and call it a day. But if you do the math and know what you are doing and it suits your needs, 6th order and other higher orders are fine.
Old 19th November 2019, 06:43 PM   #12
merajsalek is offline merajsalek  Australia
So with the WinISD program my cabinets are 16L (50hz) & 48 L (24hz).
Which version of winISD are you using...?
Old 23rd November 2019, 12:41 AM   #13
gigigirl is offline gigigirl
Hi, I am using WinISD 0.44
Cheers
Old 23rd November 2019, 02:57 AM   #14
DonVK is offline DonVK  Canada
DonVK's Avatar
I've used DCS305 in a BP6 at SonoTube and SewerPipe BP6 Subwoofer
There are some measurements and design choices in that thread. I still use it. It's unusual but will probably be converted to a "box" at some point
Old 23rd November 2019, 03:17 AM   #15
GM is offline GM  United States
GM's Avatar
Definitely need to upgrade: WinISD - Linearteam
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd November 2019, 04:25 AM   #16
freddi is offline freddi  United States
freddi's Avatar
6th Order Sub
FWIW here's 60 liters total for both chambers - add whatever vent works for total internal volume, plus 10mH inductor and ~900uF series cap
maybe the front chamber vent could be external. It could be a bundle of smaller diameter pipes like a "Pan-pipe" with the staggered ends inside or outside the chamber. I don't know how much reduction stuffing in the rear chamber would have ?
Old 23rd November 2019, 05:00 AM   #17
Hi Guy's thanks for the input. I have tried both the newer versions of WinISD & cannot get them to load. I used the earlier version for my current 6th order subs & they worked out quiet well. But compared to my now main speakers they are efficient enough, & when I push them with my MiniDSP my amp shuts off.
Cheers
6th Order SubHide this!Advertise here!
would a 3rd order box's GD be audible vs 2nd order in an average room? freddi Subwoofers 2 27th June 2019 08:47 AM
Distortion through Early Effect - mainly low Order or high Order Components ? tiefbassuebertr Solid State 24 20th May 2018 02:29 AM
WWYD? Higher order acoustic slopes and lower order targets cuibono Multi-Way 3 4th December 2009 12:36 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 08:15 PM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 11th April 2007 12:58 AM
Copyright ©1999-2019 diyAudio
