Damping material is useful only in sealed subs? Or will it work in ported subs also?
Old 27th November 2019, 10:33 AM   #21
mart34 is offline mart34  England
Damping in bass reflex subs is clearly preferred by some of the best sub manufacturers in the world.
First image - SVS PB13 Ultra, with lots of Polyester Fibre sheet (BAF Wadding)
Second image - RBH 1212, with Polyster Fibre sheet (BAF Wadding) and open cell foam near the port.
Old 28th November 2019, 12:59 PM   #22
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
They obviously use stuffing to minimize port resonances from reflecting back to the tube.
Radikal aktivist AINOgradient speaker project
Old 28th November 2019, 03:16 PM   #23
Agreed. I know this wasnt really the subject of the thread starters original post, but damping IMO clearly should be used. I have a build thread with my sub, and I haven't applied any damping so far. My original thinking was, I'd made no compromise in the enclosure size, so didn't need it. But having used it now for two months, I am struggling with upper bass and lower midrange bleeding through the drivers. Theres no box resonance, due to thickness and bracing, but there are definitely reflections. Another issue I've noticed very recently, is that although I dont have port noise/chuffing, the box seems to howl at low frequencies <20Hz), sounds like the sound of the air moving through the box/port. I believe I'll significantly reduce this with lining of the walls.
Damping material is useful only in sealed subs? Or will it work in ported subs also?Hide this!Advertise here!
what TS parameters to look at... to build compact sealed or ported subs audfrknaveen Subwoofers 14 7th September 2019 10:24 PM
Ported and sealed subs in the same room? homebuilder Subwoofers 28 6th February 2018 10:01 PM
Technical question on sealed vs ported subs beanbag Subwoofers 57 23rd March 2014 09:57 PM
Fibrous Damping Material in Subs, Why Bother? Travis Gibby Subwoofers 12 20th November 2005 01:16 AM
Copyright ©1999-2019 diyAudio
