Damping material is useful only in sealed subs? Or will it work in ported subs also?
Old 14th November 2019, 06:56 AM   #11
wonderfulaudio is offline wonderfulaudio
Originally Posted by audfrknaveen View Post
Infact, the only reason looking for damping material is because my simulation graph shows 3db peak near rolloff.
The room dominates the sub's response. Dips of ~15 db are common. 3dB will get lost, in fact Earl has often said that free field response of sub has very little meaning in room.
Old 15th November 2019, 02:07 AM   #12
snappyturtle is offline snappyturtle  United States
dB v2
Old 15th November 2019, 02:38 AM   #13
bentoronto is offline bentoronto  Canada
Originally Posted by snappyturtle View Post
Again, Data-bass has the data. As I said in post #5, adding fluff reduces the bad sound although trivially lowering the loudness. Might confuse your sim; who cares? Seems a no-brainer.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 15th November 2019, 04:06 PM   #14
djn is online now djn  United States
djn's Avatar
I am just now starting a new project using 10" full range field coil drivers and posted a question about Plywood vs MDF. I got a LOT of great responses but the one thing someone posted was this video about damping cabinets. It is an engineering approach and it the end he tested Decidamp to deaden cabs. I'll be using it on this build as test results show it kills vibration really well in a CLD configuration.
The damping discussion starts around 27 minutes into the video
YouTube
Viscoelastic Damper Paint, Industrial Damper | Pyrotek
Old 15th November 2019, 04:07 PM   #15
djn's Avatar
Ooops, maybe I misunderstood the OPs intent. I thought he was asking about damping the cabinets vs. the signal.
Old 15th November 2019, 04:23 PM   #16
Volume damping not walls, at least as per post #1.
But the viscoelastic link you posted in your signature deserves to be more widely known on this forum. Great stuff, although generally used on thin metal sheets, not speaker walls. Variants available from automobile specialty stores made from latex paint stuffed with cork bits.
B.
Old 15th November 2019, 05:59 PM   #17
djn's Avatar
I like the decidamp because it is also a glue that does not need a ton of pressure to set and is MORE effective with a thinner layer. On my project I am building the speaker cabs with plywood and then gluing on plywood panels to the inside walls so I don't have to cut glued up plywood with the sticky stuff already applied......that messes with the table saw blade.
Old 16th November 2019, 07:54 AM   #18
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Some tests and measurements dB v2
I put some old pillows inside my 270liter closed box subs, but none in 30liter BR or closed boxes. One pillow on the dead end of a 50 liter 80cm long tube box which is the woofer in 3-way, crossed LR2 300Hz. All just out of intuition, I didn't make comparative measurements.
Radikal aktivist AINOgradient speaker project
Old 16th November 2019, 01:00 PM   #19
What are those two curves (AKA the good one and the bad one)? I can't make sense of your text.
B.
Old 16th November 2019, 05:13 PM   #20
Juhazi's Avatar
Clik the link, it comes from there (the pale blue text "dB v2")
That page was linked to earlier by snappyturtle in post #12 Dark purple line is with lining/stuffing, the green one without.
Then I tell about my personal experience, without response graphs.
Damping material is useful only in sealed subs? Or will it work in ported subs also?Hide this!Advertise here!
what TS parameters to look at... to build compact sealed or ported subs audfrknaveen Subwoofers 14 7th September 2019 10:24 PM
Ported and sealed subs in the same room? homebuilder Subwoofers 28 6th February 2018 10:01 PM
Technical question on sealed vs ported subs beanbag Subwoofers 57 23rd March 2014 09:57 PM
Fibrous Damping Material in Subs, Why Bother? Travis Gibby Subwoofers 12 20th November 2005 01:16 AM
Copyright ©1999-2019 diyAudio
