Ported sub with dual 12" drivers - build pics
Ported sub with dual 12" drivers - build pics Please consider donating to help us continue to serve you.
Old 11th November 2019, 02:40 AM   #1
audfrknaveen is offline audfrknaveen  India
Default Ported sub with dual 12" drivers - build pics
Hey guys,
I started building a ported sub with two 12" drivers for my HT.
It is just half way through, see the attached pics. Will post some more pics as i progress.
Naveen
Old 11th November 2019, 07:26 AM   #2
mart34 is offline mart34  England
Looks awesome! Nice bracing! What drivers are you using? Looking forward to seeing this one progress
Old 12th November 2019, 06:42 PM   #3
I added one more set of small bracing, connecting the existing bracing.
Coming to the drivers they are 12" 200W drivers made by an Indian OEM.
They export drivers to some well known brands as far as I know.
I will post the finished sub pics in few days ...
Old 14th November 2019, 06:18 PM   #4
This is how it looks, and i will add one more layer of plywood for the bottom face.
Old 21st November 2019, 07:22 AM   #5
This looks awesome, great build. Looks like the XTZ 3x12, that has a similar front facing port. Also looks like the RBH 1212. What's the port tuning frequency?
Old 21st November 2019, 09:04 AM   #6
well... as per simulation, this sub should give the following output:
This has F3 around 31Hz, F6 around 27Hz and F10 around 22Hz.
With 400w power it is expected to deliver 114db@31Hz, 111db@27Hz and 106db@22 hz.
Simulation graph is nearly flat and has a smooth rolloff. Group delay and vent air velocity etc are decent.
Actual performance has to be measured.
Old 21st November 2019, 09:12 AM   #7
Final internal bracing is shown in attached image
Old 21st November 2019, 01:45 PM   #8
Nice! Regarding the actual permance, biggest contributor there will be the room you intend to play it in.
Ported sub with dual 12" drivers - build picsHide this!Advertise here!
Ported dual 18 RVP18 build thread SpeakerBuilderMello Subwoofers 34 31st July 2018 04:39 PM
8" Slot Ported Monacor Subwoofer Build grahamgraham Subwoofers 13 12th September 2017 08:02 AM
10" ported sub build rexhex Subwoofers 10 24th April 2016 04:27 PM
deliberate 'bad' tuning of dual ported chambers with identical drivers in 2-way MTM nannoo Multi-Way 13 9th August 2013 06:59 PM
Dual Sealed 12" Build with facing Drivers scottandmo Subwoofers 7 3rd August 2010 03:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
