Cone travel one way more than the other
Old 7th November 2019, 05:45 AM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Speaker manufacturer here, agree with Xoc1, suspect poorly reconed speaker.
Only other possibility is program wave assymmetry, but reversing connections dispels that possibility.
Never heard of port rectification, assume effect if present would not explain such a gross difference, BUT you can mount speaker the other way (even if it requires mounting it from the outside) to test that possibility.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 7th November 2019, 06:44 AM   #12
papasteack is online now papasteack  France
Hard spider probably help. Low Vas driver. Servo driver do not insure cone is centered. It doesn't track center position. It's only AC feedback. I suspect BCspeakers ipal pressure sensor feedback each side of the cone to limit better than accelerometer DC offset by tracking pressure difference mean of each side on the cone. Pressure can be tracked to DC contrary to Acceleration. So it should gives more headroom.
Old 7th November 2019, 07:02 AM   #13
whgeiger is offline whgeiger  United States
Default ?
I did not specify sensor type that is placed in the feedback loop to implement servo control. As you point out there are superior implementation methods. WHG
Old 7th November 2019, 07:59 AM   #14
While about it, do you know any other type of sensor that can somewhat track, even indirectly, DC position ?
Old 7th November 2019, 09:26 AM   #15
David Morison is offline David Morison  Scotland
I believe Klippel analysis is done using a laser - so that could be one (admittedly, expensive and perhaps impractical) option?
Old 7th November 2019, 01:51 PM   #16
freddi is offline freddi  United States
freddi's Avatar
re:"port rectification" - I've seen offset which think "may" be described as such. Its when the port flow stops having a symmetrical back and forth behavior and to a way of thinking, the cone is offset like a DC component has been introduced.
Jon Risch has a patent for asymmetric flow vents to cool speaker motors and IIRC, help with asymmetries.
I've seen it called "vent rectification" somewhere in the past.
Its mentioned here:
Maximizing Performance from Loudspeaker Ports.pdf - Google Drive
Old 7th November 2019, 10:38 PM   #17
Originally Posted by tonskulus View Post
Sometimes I have noticed the same, cone is moving more inwards at some frequencies (especially in ported enclosures and some tapped horns etc). This sympton may actually lead to spider/suspension sagging.
Any good solutions for that "port rectification"? could not find any documents..
While I have not undertaken design of this particular type of loudspeaker control system, I suspect that the offset can be corrected by evaluation of the difference signal. WHG
Old 7th November 2019, 10:41 PM   #18
While I have not undertaken design of this particular type of loudspeaker control system, I suspect that the offset can be corrected by evaluation of the difference signal. For certain type of sensor implementation this will be easier to accomplish than others. WHG
Cone travel one way more than the otherHide this!Advertise here!
Travel to the US and tipping Stuey The Lounge 15 13th December 2015 01:00 AM
Increase cone mass to rid cone resonance; worth it? bikinpunk Multi-Way 6 30th July 2010 06:08 PM
Repair Vifa D6.8 Plastic Speaker Cone with hole in cone excetara2 Multi-Way 0 30th August 2009 03:32 AM
How does sound travel? lumanauw Everything Else 25 28th November 2004 06:46 AM
speaker travel box? timfishy Multi-Way 8 30th August 2004 09:50 PM
Copyright ©1999-2019 diyAudio
