Plate amplifier with speakon input as REL
Old 2nd November 2019, 07:56 PM   #1
gothi is offline gothi
Default Plate amplifier with speakon input as REL
Is there a nice plate amplifier with speakon input as REL or BK for about 500 EUR? thanks! gothi
Old 4th November 2019, 05:06 PM   #2
weltersys is offline weltersys  United States
weltersys's Avatar
Speakon connectors are used for amplifier output, not input.
Don't know what you mean by "as REL or BK".
Old 4th November 2019, 06:04 PM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
XLR or RCA connectors are inputs.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 4th November 2019, 06:12 PM   #4
Jag768 is offline Jag768  Netherlands
Rel subs use speakon for their high level inputs
Old 4th November 2019, 06:17 PM   #5
Please see the attached file. On left side sub amplifier input, on ritght side stereo amplifier outputs for loudspeakers. I am looking for the same option...
File Type: png left sub amplifier ritght stereo integrated amplifier.png (55.2 KB, 73 views)
Old 4th November 2019, 06:57 PM   #6
That is a non standard design and will cause problems. The Speakon is designed purely as a loudspeaker coupling connector.
In a standard 4 way connector pins 1+ & 1- are full range, pins 2+ & 2- are treble in mixed bi powered speaker systems.
In the 8way Speakon, pins 1+ & 1- are sub, 2+ & 2- are bass, 3+ & 3- are mid range and 4+ & 4- are used as treble.
See Neutrik's link for the correct wiring; https://www.neutrik.com/en/neutrik/p...ble-connectors
Old 10th November 2019, 08:59 PM   #7
kujina is offline kujina  United Kingdom
Hello Gothi
You can buy them from BK!
Sub Bass Plate Amplifiers
Old 11th November 2019, 08:27 AM   #8
Originally Posted by kujina View Post
Hello Gothi
Good idea, indeed plate amplifiers are avalaible. thank you!
Old 11th November 2019, 10:04 AM   #9
chris661 is offline chris661  United Kingdom
chris661's Avatar
REL subwoofers are designed so that you can integrate them with a conventional HiFi system - they use an NL4 speaker-level input which is then attenuated and summed to mono to feed signal to the internal amplifier.
A rather good idea, if you ask me.
Chris
Old 11th November 2019, 10:32 AM   #10
Samsara is offline Samsara  France
Beware if the source is bridged amplifier, because the BK speakon input is unbalanced (must check about REL).
Plate amplifier with speakon input as RELHide this!Advertise here!
switchable speakon jack plate sine143 Subwoofers 5 16th November 2014 01:06 AM
HIGHLEVEL INPUT IN PLATE AMP! reji Analog Line Level 1 10th June 2013 07:27 AM
Sub plate amp with Neutrik Speakon input? D_Dubya Subwoofers 1 15th July 2009 03:02 PM
Subwoofer Plate Amplifier Base Plate supplier? jwells777 Parts 1 11th May 2003 08:40 AM
Copyright ©1999-2019 diyAudio
