shallow subwoofer options
Old 4th November 2019, 02:35 PM   #21
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi umut1001,All
FYI:
b
File Type: jpg SB34NRX75-6_in-too Small-Narrow_SealedBox-.JPG (832.9 KB, 94 views)
Old 4th November 2019, 07:28 PM   #22
umut1001 is offline umut1001  Europe
umut1001's Avatar
Hi Bjorno!
Thank you for your help!I just came home and saw your project. It seems SB34 will not fit well in this box.
But there is good news! I have talked to wife now and she give permittion for a deeper box.I will buy some extra little furnitures for home and got permittion this way (now we dealed for 23cm wide,104cm high and 39cm deep)
Best regards
"Peace at Home, Peace in the World"
http://stores.ebay.com/Paradise-of-H...dio-components www.hiendparadise.com
Old 5th November 2019, 10:06 AM   #23
umut1001's Avatar
Default Hornresp calculations-filling
Hi.I made some calculations for the bigger box.Thank you
Old 5th November 2019, 07:50 PM   #24
umut1001's Avatar
Hi.I read that polyfiber is not good for stuffing so i decided to buy some acoustic foam.At Bauhaus i found these ones attached.50x50cm and at different heights 7cm ,5cm and 4cm.(I found cheaper ones on internet though)
@Bjorno you stuffed end and beginning of the box.Why did not you fill all the box to increase deep bass SPL? Is it stuffed by polyfiber or acoustic foam?I did not see any information about density of stuffing on your project.And what should be density of acoustic sponge?Is it good to use 50density? There are many types available on internet.
Thank you for your answers.Best regards
Old 5th November 2019, 10:12 PM   #25
GM is offline GM  United States
GM's Avatar
I wonder why? GlassWolf's Pages
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th November 2019, 08:11 AM   #26
umut1001's Avatar
Hi.Ok i am cutting the mdf panels today.
From web site
"A few rules of thumb: Stuff small enclosures – those with up to about 3 cubic feet of internal volume or less – with 1.5 pounds of fiberfill for each cubic foot of internal volume and you should get about a 30-percent increase in box volume without seriously affecting other performance variables"
By
TOM NOUSAINE
RIP
Will fill 1,7kilograms of polyfiber in 68liters of box.
So 68*1,3=88,4liters effective volume.
Best Regards
shallow subwoofer optionsHide this!Advertise here!
Shallow mid-range enclosure inside a 3-way?? too shallow?? Kooshball Multi-Way 8 4th November 2012 12:40 AM
Velodyne Subwoofer Replace Or Fix Options. Please Suggest dangdang Subwoofers 2 7th September 2012 07:40 PM
If space is not an issue, SIX subwoofer options noviygera Subwoofers 11 23rd April 2011 03:28 AM
Off-receiver; subwoofer timing control options Ektalog Subwoofers 0 24th February 2010 05:44 AM
cheap Subwoofer options The Drake Subwoofers 7 7th December 2009 09:16 AM
Copyright ©1999-2019 diyAudio
