BMS 12S330 - PLANS Help
Old 26th October 2019, 09:23 PM   #21
GM is offline GM  United States
GM's Avatar
Originally Posted by bjorno View Post
Hi All,
FYI:
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th October 2019, 11:55 PM   #22
mart34 is offline mart34  England
Originally Posted by GM View Post
Bjornos Legendary response
Old 1st November 2019, 06:32 PM   #23
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
He's a modeling monster!
Old 2nd November 2019, 12:32 AM   #24
Tonefarm is offline Tonefarm
Hi All,
FYI:
If you want to interface a Circular Stub to a Slot-Port: You should first calculate the equivalent Hydraulic Diameter for your intended Slot-Port Area and make equal to a corresponding Circular Entrance that is placed centered(middle)
to the Slot-Port if the Slot CSA Ratio is equal or less than 2/1 but if > than 2:1, consider to add Slot CSA Dividers.
Your suggested Slot has a CSA Aspect Ratio of 36.4/6= ~6.07/1 so in order to keep the Ratio below ~2/1 you need at least 3 Dividers:
Then 3 Circular Stubs should be used perpendicular to the 3 Dividing Slot Areas.
Always calculate the required Stuffing needed to control the Stub Q+anti Pressure Level and try to make the individual interfacing Stubs total Hydraulic Area as close as possible to the sum of the calculated Slot-Port Hydraulic input Areas/ # of divided Areas( Suggested here: # =3).
Tapering the Stub is also an option.
See the submitted example Picture where calculations are made to improve a Slot-Port that was too wide(=LF HOM Generator).
b
PS: I modified the HR simulation made by papasteack into a QW BR optimized for one Decade of BW; f-3 dB= ~24 Hz to f-6 dB at ~240 Hz.
Bjono,
Thanks so much for your response, my head exploded looking at the pictures you attached. I literally don't know where to start now. i cant seem to translate the math presented into the physical realm and how it reflects the physical aspects of the subwoofer port.. i need Layman's terms!
Sorry.. my guess is it will take too long to explain.
Declan
BMS 12S330 - PLANS HelpHide this!Advertise here!
BMS 12S330 for a folded horn? Augusts Subwoofers 6 6th October 2016 02:28 PM
Any plans or help to sketch up plans for bookshelf speakers for my requirements DangerAZillionVoltz Multi-Way 10 19th May 2014 11:23 PM
My Box plans help please audiobahnkid592 Car Audio 23 23rd January 2009 11:10 PM
Sub with six BMS 12S330 drivers a007udio Subwoofers 4 28th September 2007 06:21 PM
VTA plans someone? Zen Mod Analogue Source 7 31st January 2003 01:56 AM
Copyright ©1999-2019 diyAudio
