Vintage PA Subs
Vintage PA Subs
Old 11th October 2019, 02:30 AM   #11
GM is offline GM  United States
GM's Avatar
Correct, though the driver specs you posted are close enough to others I'm aware of, just the published response is way off WRT to how flat it is, i.e. much more 'humpback' like HR sims due to being a too high Qt driver for this cab alignment [too small, too high tuned].
It's only a 'sub' by vintage prosound requirements as up until fairly recently, prosound was ~flat from 80-300 Hz, -12 dB/60 Hz, -24 dB/40 Hz simply because the music didn't have much bass to the point where 'sub' bass was below 40 Hz, with 'infra' bass below 20 Hz till THX became the cinema norm, so reclassified as 'sub' bass below 20 Hz in recent decades.
With a 40 Hz Fs, the only way it will get anywhere near 20 Hz at a reasonably loud output is with a small room size BLH, so think of this 'sub' as one for a low B bass guitar.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th October 2019, 04:37 AM   #12
Gwho is offline Gwho  United States
GM,
Thank you for the information. I definitely was barking up the wrong tree. I appreciate the knowledge.
gwho
Old 11th October 2019, 09:58 AM   #13
GM's Avatar
Old 11th October 2019, 12:11 PM   #14
TBTL is offline TBTL  Germany
Try blocking off the ports and equalizing them flat to 35 Hz. Then you can judge if these have sufficient output for your needs.
Old 11th October 2019, 04:37 PM   #15
TBTL,
I will try that but with much less equalization to see how it sounds vs leaving it stock.
Gary
Vintage PA SubsHide this!Advertise here!
Verifying Picofarad lvl Vintage Capacitors From BF-50 Vintage Cap Tester? ZoSoNCSU Equipment & Tools 7 7th April 2018 05:13 PM
Can my vintage receiver power dual 8ohm subs? stampants Subwoofers 8 19th November 2014 08:30 PM
Multiple-Small-Subs vs A-Few-Large-Subs Eskae Subwoofers 11 21st August 2013 09:17 PM
Vintage Richard Long Bertha/vintage JBL artscrafts14 PA Systems 6 5th July 2012 08:19 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 01:44 AM
Copyright ©1999-2019 diyAudio
