Transmission line subwoofer build
Transmission line subwoofer build Please consider donating to help us continue to serve you.
Old 16th October 2019, 11:18 PM   #11
bentoronto is offline bentoronto  Canada
Originally Posted by Bjohannesen View Post
Hi
Just some comments:
- Stuffing helps controlling cone movement. In a TL sub you should not stuff too dense, however.
- I have made TL subs with the driver at the closed end. Any dips and peaks are above the cross over frequency any way.
- Port close to the driver is the best design. I have simmed this with MJK's models.
Please post the data you collected that led you to those opinions.
B.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped"
Old 17th October 2019, 02:44 AM   #12
Brian Steele is offline Brian Steele  Grenada
That would be dependent on how low the subwoofer is tuned (Fb) and the x-over frequency. If you tune to your subwoofer to operate over a narrow range of frequencies (bearing in mind that you'd want to put the x-over point about an octave away from any gross variations in the subwoofer's response if you want a smooth transition to your main speakers), then sure, that would work.
www.diysubwoofers.org
Transmission line subwoofer buildHide this!Advertise here!
Transmission Line Speaker Build using Alpair 7.3 speakers, first build. vishalk Full Range 123 29th March 2017 01:22 AM
transmission line subwoofer / Car audio iFearFractals Car Audio 3 5th November 2014 01:32 PM
how to build a transmission line e-side Multi-Way 4 15th July 2005 08:24 PM
subwoofer transmission line dcampbell1955 Subwoofers 6 10th December 2003 06:23 PM
Transmission line subwoofer question Street Subwoofers 16 14th August 2003 03:33 AM
Copyright ©1999-2019 diyAudio
