Subwoofer 30l possible?
Old 18th September 2019, 09:36 PM   #1
eilon is offline eilon  Germany
Default Subwoofer 30l possible?
Hey,
I would love to build a bigger subwoofer, but I am stuck to the outside measurement of 33x33x39cm.
Do you have any recommendation for a subwoofer chassis around 30l?
I want to build a Subwoofer which fits into my Ikea Kallax shelf.
Amplifier: X1500H Denon
Front Speaker: BigYellowTaxi MK2
Rear: Teufel Motiv 10
Old 18th September 2019, 09:55 PM   #2
Think is offline Think  Netherlands
I advise against that idea as you will get resonances in the Kallax but many 8" and some 10" will do fine in that size box.
Old 19th September 2019, 12:05 AM   #3
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
You can always modify the shelves to fit in something bigger
Old 19th September 2019, 01:37 AM   #4
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
I say go for it, my only concern would be vibration knocking stuff off the shelves. If you could figure out a way to go dual opposed that would be good.
An Alpine type r or SBA sb23mfcl45 do well in small enclosures with response into the mid 20hz range.
Old 19th September 2019, 08:02 AM   #5
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
I've got a 2x4 kallax bookshelf on top of my sub.
I've always wanted to re build the sub to look exactly the same as the Kallax and use book fabric as grill to totally hide it.
Rob
Old 19th September 2019, 10:53 AM   #6
Do you mean the SWR-12D2?
Old 19th September 2019, 02:32 PM   #7
I was thinking the 8”.
Old 19th September 2019, 06:37 PM   #8
Jag768 is offline Jag768  Netherlands
Friend of mine built (or actually I built it for him) a sub using a peerless xls10 of that size in put in n an Ikea cabinet as well; no vibration issues
Old 19th September 2019, 06:41 PM   #9
The xls10 would be a good option as well.
Old 20th September 2019, 08:01 AM   #10
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Sealed small box and a 12" SW driver with some eq from the plate amp will be nice and easy solution. Construction must bew very rigid, extra cross-braces recommended. 2x8" is also possible! 2x10" will suffer from too small air volume.
As driver consider also
10'' SB29SWNRX-S75-6 :: SB Acoustics
Radikal aktivist AINOgradient speaker project
Subwoofer 30l possible?Hide this!Advertise here!
FS in Los Angeles: subwoofer, subwoofer cabinet, oscilliscope, KEF center... taloyd Swap Meet 77 1st May 2019 08:18 PM
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 27 9th September 2012 10:42 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 03:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 02:11 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
Copyright ©1999-2019 diyAudio
