Old 5th October 2019, 07:28 PM   #41
mart34 is offline mart34  England
Photos correct way up
Old 5th October 2019, 09:12 PM   #42
Ok, so looking closely at Bjornos modelling, clearly I should have used some stuffing to eliminate the spikes at around the port resonance. This was an oversight on my part, but lessons learnt! This was a trial for me, and I'm really happy with the results. My floorstanders have useable response down to approx 45Hz, so this design was intended mainly to fill from there down. My "as built" port length was 1.3meters.
Old 5th October 2019, 09:13 PM   #43
Ps - I'll look at getting some poly fill in the enclosure - further research to be done!
Old 12th October 2019, 03:54 PM   #44
Put 4 coats of primer on, leaving the top coat for next summer, should give the enclosure time to climatize, possibility for seems to open up, so don't see point in finishing it yet anyway.
All sounding well, really happy with it. When I open it up next year, I'll consider putting acoustic lining on the panel behind the drivers, as I suspect this is contributing to a slightly muddy upper bass - reflections coming through the driver. It's barely noticeable, I'm just being quite picky
Any advice on what type of lining might be suitable? I've seen some eggbox self adhesive foam which might be ok - Eggbox Profile Foam Laminate Panel
Old 25th October 2019, 08:43 PM   #45
Measurements with UMIK. Pink Line is natural response with only the AV Amps 60Hz - 24dB/octave LPF. Blue Line is the same but with mild PEQ applied.
Each of the two lines are averages derived from 5 positions (across 3 seats on a sofa), with the mic in the exact same spot for each of the 5 x before and after PEQ measurements.
Martin
Old 26th October 2019, 12:39 AM   #46
5th element is offline 5th element  United Kingdom
5th element's Avatar
These have turned out very nice!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 26th October 2019, 03:05 PM   #47
Thanks. I'm really happy with it. Here's some more measurements. This time, I took 27 measurements from 9 points across the whole of my corner four seat sofa. These are averages of 9 measurements. I've included the raw measurements too.
Pink Line - 250Hz 24dB/oct LPF.
Blue Line - Above + PEQ
Green Line - Above + 16Hz BW 30dB/oct HPF + 100Hz BW 12dB/oct LPF
I also played a song with 30Hz content, and recorded 116.5dB on the REW meter with UMIK. Really should have done a sweep as well, but headache and neighbours inhibited me. I'll post that another weekend.
Thanks for everyone's help on this forum. Cheers, Martin
Old 26th October 2019, 05:41 PM   #48
Jag768 is offline Jag768  Netherlands
Nice looking sub, good work. And good looking in room response for a single sub!
Old 27th October 2019, 12:11 AM   #49
Thanks Jag768, and many thanks for the inspiration along the way.
The reality is I would not have built this without the contributions from diyaudio. This was a learning experience for myself, and I can only hope the record of my design (including its faults), will help others in the future.
Cheers, Martin
Old 30th October 2019, 10:37 AM   #50
Jag768. I forgot to mention - I bought the Minidsp 2x4 HD version. The graphs above show a subsonic filter applied, with what appears to be no peaking. I know this isn't the best method to test, should really be done with electrical measurements directly at the input and output of the minidsp, but I'm guessing any peaking would show up in the green response curve?
Cheers
Subwoofer box with round port tuned to 20Hz Hadoda Subwoofers 6 22nd May 2018 09:35 PM
Help recalculating ny port to a slot port, my math is ****.. MathiasJK Subwoofers 6 27th January 2018 01:38 PM
Is It Sensible To Use The Cabinet As Part Of The Port? (Slot Port) ReDress Subwoofers 4 19th October 2015 06:56 AM
60litre box tuned to 20Hz without PR? SkinnyBoy Multi-Way 28 16th March 2004 01:05 AM
Slot loading versus tuned port coolkhoa Multi-Way 5 20th January 2004 10:18 PM
Copyright ©1999-2019 diyAudio
