EV T18
EV T18
Old 5th September 2019, 02:06 AM   #31
rnbmccain is offline rnbmccain
Default Keystone?
Originally Posted by rnbmccain View Post
I've had four back surgeries and I can tell you that two 810 cabs and something that will go down to two ohms to run them, is the holy grail of bass guitar.
Can you give me a link on Keystone?
Old 5th September 2019, 02:23 AM   #32
Originally Posted by freddi View Post
fwiw I think a 2/3 scale T18 looks pretty good when 2 cabinets are run
just ~60 liters airspace per box
Thank You, Freddi! I will test with the Dayton pa310 12"
Old 5th September 2019, 02:25 AM   #33
Originally Posted by Rademakers View Post
I hear he has an e-mail address but he won't respond if you call him a creature
Thank You.
Old 5th September 2019, 04:29 PM   #34
weltersys is offline weltersys  United States
weltersys's Avatar
Keystone Sub Using 18, 15, & 12 Inch Speakers
As the designer of the Keystone sub, I can say that it would not be my first choice as a bass guitar speaker unless using it below something that sounds good above 200Hz or so.
Old 7th September 2019, 08:11 PM   #35
freddi is offline freddi  United States
freddi's Avatar
EV T18
fwiw PA310 basic sim. It should hold down 40v peaks within its xmax rating. In a Karlson 12 crossing over to a slotted pipe tweeter, its murky as hell compared to Kappa12a - but that may not be the way it sounds with bass guitar. It might have a nice balance.
Old 15th September 2019, 08:26 PM   #36
Go on Partsexpress.com and look under ProAudio, they list all the speaker specs., and they will even give tech info on box size and porting. I like parts express.
Old 15th September 2019, 08:45 PM   #37
The CUBO 12 is not the same as the T18 internally but I like the box size. I would like a shot at the port like on a T18. That would allow for more definition and projection with a bass guitar. This kind of box does double the duty of a bass reflex box using less power.
Old 15th September 2019, 08:48 PM   #38
My brother is a cabinet maker, He has two T18's in my shed and two more in cutouts. T18's are not for gigging bass players or small club's but a T12 is just the box to handle big and small. How do I get the right numbers for a T12 because the Cubo12 is a bandpass box.
My bad, the CUBO12 is not a bandpass box.
Old 16th October 2019, 02:40 AM   #39
Default 212
More on that: I have used 2 112 boxes outside with Dayton's pushed as far as I dare. The P.A. guy says that they sound great. Well then, Two midget T18's
should make everything twice as good.
Old 20th October 2019, 08:36 PM   #40
freddi's Avatar
EV T18
if T18 were scaled 0.83X for a 15" it would tune much like the old JBL C40 "Harkness". The Harkness should be stronger around 150Hz but otherwise pretty similar. A little Karlson box tuned ~55Hz (say 27"H x 20"Wx 13.5"D) about 32 liters smaller than the 0.83 scaled T18 would be about as good but probably a more subdued midrange - oh maybe not as the Karlson's on is facing outwards - lol
EV T18Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
