slim and tall 12" ported subwoofer - port location query
Old 22nd July 2019, 12:07 PM   #1
audfrknaveen is offline audfrknaveen  India
Default slim and tall 12" ported subwoofer - port location query
Hi All,
Due to some space constraints, I have to build a subwoofer nearly 30" tall.
Please see the attached image and suggest which location is better for the port.
Near to the driver? or Away from the driver? Does it have any effect on performance ???
Thanks in advance...
Last edited by audfrknaveen; 22nd July 2019 at 12:08 PM. Reason: forgot attachment
Old 22nd July 2019, 02:29 PM   #2
RichK is offline RichK  Canada
Suggestion: port and driver located close to boundary- floor.
Old 22nd July 2019, 04:05 PM   #3
wonderfulaudio is offline wonderfulaudio
At the sub frequencies, makes no difference
Old 23rd July 2019, 02:29 AM   #4
Two different answers
I'm wondering port location has any positive or negative effect on bass. Is there anything like phase matching etc ???
Old 23rd July 2019, 07:22 AM   #5
The port operates in about an octave at most. With a 30hz tune, the highest freq is 60hz, thats (345/60) 5.75m in wavelength. To get boundary loading, the source must be within 1/4 WL, which is about 1.43m from the floor. Assuming a sane height of the enclosure, its location does not matter.
More so, if the tuning is lower.
There is no difference in phase. Take the port location to extreme, on top-rear, even then its going to be in phase.
Room acoustics (phase and SPL) will overshadow everything else.
Old 23rd July 2019, 12:27 PM   #6
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
Would cooling via airflow be a factor?
Old 25th July 2019, 06:54 AM   #7
started building it ... see the pics
slim and tall 12" ported subwoofer - port location queryHide this!Advertise here!
Very tall and slim baffle for single driver - will it work? sonorsnoopy Full Range 5 7th July 2015 11:21 AM
Idea for tall slim B3s design- MMTMM joe carrow Multi-Way 59 27th November 2009 10:11 PM
Dimensions to make the enclosure look tall and slim. rakeshln Multi-Way 15 8th July 2004 03:12 AM
Car Ported Subwoofer: Can the port be Outside the box? Noob-in-a-Camry Subwoofers 11 23rd May 2002 01:59 PM
Copyright ©1999-2019 diyAudio
