small sealed sub driver recommendations?
Old 22nd July 2019, 08:42 AM   #1
skewIF is offline skewIF  Australia
Default small sealed sub driver recommendations?
greetings,
iíd like to build 2 small sealed passive subs to support full range speakers (jordan jx92s in sealed 9 litre enclosures). they will be driven by 2 channels of a primare A30/5 5 channel amp (120rms into 8ohms, 200rms into 4 ohms). active crossover and room correction via dsp.
iím having difficulty finding a suitable driver. iím not a designer and there seems to be hundreds of drivers to sort through, so i thought maybe someone else might have gone down this road recently and could offer suggestions. iím listening mainly to small ensemble music of various kinds, at moderate levels in a moderately sized room, so no home theatre special effects requirements.
perhaps naively i figured i could build a simple sealed enclosure of say 20-25 litres that would do the job given the right driver. cost isnít necessarily a consideration at this point.
Old 22nd July 2019, 09:42 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
In the 20-25L range, I'd be looking at an 8-10" driver. Efficiency (and therefore ultimate output) won't be particularly high, but it sounds like you're not looking for party levels.
IIRC, Faital Pro is available at sensible money in Australia. They do have a few drivers with rubber surrounds etc that look more geared towards HiFi and studio speakers.
Chris
My work: www.grimshawaudio.com
Old 22nd July 2019, 09:57 AM   #3
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hi, nice speakers, I have a pair of Eikonas with subs.
For a small sealed enclosure you might consider using EQ. Linkwitz transform is an option as here for example Pluto + subwoofer Linkwitz Transform Subwoofer Equaliser or a simpler method described here Sub-Woofer Controller
Old 22nd July 2019, 01:44 PM   #4
hi chris, thanks for this. even though i’m flying an australian flag i’m building these in vienna, so the range you’ve pointed at are accessible. know of any other possibilities here in europe?
Old 22nd July 2019, 01:46 PM   #5
hi scott,
many thanks for this info. i’ll digest it. how have you configured your eikonas?
chris
Old 22nd July 2019, 02:07 PM   #6
cph2000 is offline cph2000  Denmark
Take a look at these
Shallow Subwoofers :: SB Acoustics
Old 22nd July 2019, 02:39 PM   #7
Originally Posted by skewIF View Post
hi scott,
many thanks for this info. iíll digest it. how have you configured your eikonas?
chris
You're welcome. The Eikonas are in the VTL cabinet, sometimes I use them fullrange, but usually I crossover at about 100Hz to a pair of U-frame OB subs with 2 12" woofers in each, so not quite what you have in mind
Old 22nd July 2019, 03:22 PM   #8
smallangryboy is offline smallangryboy  United Kingdom
10" Peerless 830452 by Tymphany would be a good start in that sort of box but I think it would be reasonably hard to drive. You would be better having them driven with a plate amp. I know this is a DIY forum but you would do worse than one or two of the BK Eelctronics XLS 200 though I appreciate you may not get them in your neck of the woods. You could copy the design with a suitable alternative amp though.
Old 22nd July 2019, 08:26 PM   #9
Originally Posted by cph2000 View Post
great! they look interesting for sure.
Old 22nd July 2019, 11:25 PM   #10
djn is offline djn  United States
djn's Avatar
Here is a great small sub.
The Triska Sub
small sealed sub driver recommendations?Hide this!Advertise here!
Cheap 8" midbass driver for small sealed system - recommendations please! bluetomgold Multi-Way 12 23rd May 2018 07:49 AM
Small, sealed driver help! nbriles2000 Full Range 3 27th January 2014 04:04 PM
Driver and enclosure recommendations for small room. HiVi Guy Full Range 36 1st December 2011 06:17 AM
Which driver for a small sealed box. ShockValue Subwoofers 21 16th June 2005 04:25 PM
Copyright ©1999-2019 diyAudio
