15" sealed subs - simulated F3 values too high ??
Old 16th July 2019, 01:49 AM   #11
audfrknaveen is offline audfrknaveen  India
Since this is for home usage I can't accommodate huge boxes. 18"x20"x24" is maximum size I can use. With this box, my driver gives 40hz @ F6. Will that be ok for music?
Old 16th July 2019, 02:35 AM   #12
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
For most music and basically all rock/pop, yes. The room will lift the bottom end a little to make the speaker close to flat down to the lowest strings on a bass guitar. Kick drums are usually tuned higher. If you feel like you need a little more a touch of eq will help out.
Don't Procrastinate....Just Do It!
Old 16th July 2019, 02:55 AM   #13
djn is offline djn  United States
djn's Avatar
Here is my build and these are super tight, clear, and powerful.
New build
Old 16th July 2019, 07:25 AM   #14
New build
nice build with metal rods as bracing
Old 16th July 2019, 07:26 AM   #15
thanks a lot for all your suggestions guys !!!
Old 16th July 2019, 06:11 PM   #16
djn's Avatar
I like the threaded rod as it takes up much less space in the cabs.
Old 17th July 2019, 10:45 AM   #17
Think is online now Think  Netherlands
If you put the subwoofer in a corner of a room it will have the most room gain; the roll off on the low end will be a lot less then the modeling software predicts.
Old 17th July 2019, 02:16 PM   #18
I will try corner placement. And I'm building dual subs. So let's see how it sounds ....
Old 17th July 2019, 05:42 PM   #19
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Frequencies below 40Hz from a sealed woofer get assistance from boundaries (boundary gain) and room modes, alas pressurization below the lowet mode. These make the room response much "better" than simulated free-air looks. A ported woofer is much worse in this respect.
How will the subwoofer be amplified? Many plate amps have low bass boost option, often adjustable like Hypex and DaytonAudio. A large 15" driver can take this eq guite easily and it doesn't have to use hundreds of watts, at home. I have 2x15" sealed woofers in my HT room and below are some measurements without eq and xo.
Radikal aktivist AINOgradient speaker project
Old 17th July 2019, 06:21 PM   #20
djn's Avatar
For the cost of two plate amps you can buy a behringer inuke 3000DSP. That's what I use.
15" sealed subs - simulated F3 values too high ??Hide this!Advertise here!
FS in Los Angeles: two high-end sealed 12" aluminum cone subwoofers w/ 1kW amp- $635 taloyd Swap Meet 5 16th September 2018 04:39 PM
FS: OB Woofers and 15" sealed subs, NYC area nl Swap Meet 0 8th December 2017 12:55 PM
Dual opposed sealed or two seperate sealed subs? ORNJ Subwoofers 2 17th September 2012 12:48 AM
efficient 15" subs that will drop in an automotice IB setup, 10CuFt/sub sealed(ish) Puggie Subwoofers 2 1st November 2005 09:13 AM
Using "high-end" car subs for home? mazeroth Subwoofers 21 25th August 2004 01:39 PM
Copyright ©1999-2019 diyAudio
