Ported Sub to Tapped Horn. Few questions before starting
GM Word ! Hornresp for Dum... hmm... Everyone ;) - Home Theater Forum and Systems - HomeTheaterShack.com
So it gives me similar sims as BassBox Pro, except than the frequencies starts wayyyyy later (at 90Hz if I don't mistake) than 40Hz, where I'm already at 122db on BassBoxPro
It's the first time I'm using it so I may have done a mistakes, any help to correct me or that's seems alright ?
RCF LF15N401
RCF MB15N401
sim, in black the MB15N401, in grey the LF15N401
Hey. Each enclosure has its own adantages and disadvantages obviously. And performance or feasibility of these can change with required box volume. For certain weights and sizes, Tapped horn is not the best solution, while for different setup it could be. Some comparisons here seem to be a lot unfair to the bassreflex box. 10dB nonsense is rigged badly most of the time. Also with size for size, we could add TML and bandpass enclosures. I greatly recommend younto settle on sizes and weights first. Then move on with the rest.
