Ported Sub to Tapped Horn. Few questions before starting
Old 29th June 2019, 11:46 AM   #21
suparub is offline suparub
and 38Kg (driver included) for the SS15, not bad but 10Kg more than the THAM15. Any quick way how could I compare the performances of the lf15n401 on the SS15 vs the THAM15 ?
Also, I know 12mm plywood is not recommanded for drivers that are getting more than 500W, but should I try it and renforce some part of the enclosures ?
Old 30th June 2019, 06:55 AM   #22
Hi again guys, so as the weight is a critical limiter in my case, and having compared the enclosure weights of my actual ported one and the Tapped Horn ones, I'm debating if I should upgrade to a TP or just improve the design of the vented one.
Weights :
Actual : 10Kg
THAM15 : 30Kg (the lightest TP and already very heavy for me).
So on, does anyone would recommend a simple design (not forcelly TH) that would be ligther "woodwize" with this driver ? As it's a Neodium magnet it's supposed to perform well in smaller cabinets. I'm open to anything (among ported designs).
Old 1st July 2019, 12:42 AM   #23
GM is offline GM  United States
GM's Avatar
The main thing is getting enough stiffness, so panels as thin as 1/4" with more bracing can reduce weight considerably with the trade-off being build complexity. Of course as weight drops, the more speakers can 'dance', so either need to have stacks of them or some way to couple them to the floor/whatever.
The ROAR series with its 'rat's maze' layout would be my choice and start with just a 1/4" BB ply/epoxy construction and brace with small hardwood dowels as required.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st July 2019, 03:19 AM   #24
It would make a enclosure of 20/25kg indeed. But wow that's pretty thin. I'll ask on the relevant thread what other think. Thanks for the input GM
Old 1st July 2019, 03:28 AM   #25
freddi is offline freddi  United States
freddi's Avatar
from what I can see, on the low end, for practical purposes, THAM15 and SS15 are the "same" enclosure. The larger cabinet has a bit more "hit". Both exhibit ~.the same excursion and tuned ~ the same.
Old 1st July 2019, 04:04 AM   #26
GM's Avatar
You're welcome!
Not really since stiffness is primarily a function of span, so construct something like a 'bird cage' Maserati's frame and build [have built] it out of corrugated cardboard or that super thin/cheap paneling for indoor use: http://www.autominiaturen.be/data/ar...oom/m_3875.jpg
Another I've used for outdoors are made with epoxy impregnated cardboard: epoxy impregnated cardboard boxes - Google Search
Obviously, if tall, heavy weights are stacked on top, crowd abuse/whatever is an issue, then this dictates materials/construction used, otherwise no need to overbuild, just don't be doing much in the way of dropping unless the corners are triangulated and have corner protectors.
GM
Old 1st July 2019, 04:32 AM   #27
Thanks again for the analysis boss !
Wow that an surprising material to use, It is as reliable as PLY in the long term ? And yes the enclosures will def be for outdoor use.
By the way, kind of a newbie question : will there be a big DB / max SPL / Audio difference if I build 2 x THAM15 (wired in //) vs 1 x ROAR15 ? Im studding the options between sound power and weight
Old 1st July 2019, 05:10 AM   #28
Circlomanen is offline Circlomanen  Sweden
Green-red line is two THAM with 1800 watts each compared to one single ROAR15 with 1800 watts (grey line).
We live in a horizontal world, why use vertical topologies???
Old 1st July 2019, 05:52 AM   #29
freddi's Avatar
fwiw, here's two THAM15 at 500W (250 each) vs on ROAR15 at 500W
Old 1st July 2019, 06:21 AM   #30
Heroes !! Ok the choice is almost made ^^ now looking into dimensions
For info, weightwize with 12mm ply :
Option 1 (2 x THAM15) 40kg
Option 2 (1 x ROAR) 45kg
I just can't realize yet if the perceived "sound power" / SPL difference between 60Hz and 100Hz will be noticable / worst it. I know that +10DB double the perceived sound so 6DB should be +50% difference in this range. The use if for outdoor open air fields.
Edit : ok now I realize
Ported Sub to Tapped Horn. Few questions before startingHide this!Advertise here!
Tapped horn: How much does the driver's rear output load the horn? wonderfulaudio Subwoofers 4 19th April 2018 03:41 AM
why is a tapped horn more efficient than ported? 60ndown Subwoofers 34 1st September 2011 04:15 PM
Tapped Horn questions? buzzforb Subwoofers 12 16th August 2011 04:45 AM
Spiral Tapped Horn Invention Box and questions heyday Subwoofers 20 27th March 2010 07:26 PM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright ©1999-2019 diyAudio
