Sub enclosure design question
Old 22nd June 2019, 04:01 PM   #11
Augusts is offline Augusts  Latvia
This is PR 18". Not bad. Enclosure volume the same as ported without port 74L
Old 22nd June 2019, 08:29 PM   #12
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by Augusts View Post
It is louder but does not go that low as a port.
Yes, ofcourse. Because you didn't add weight! Increase the Mms and there you go.
E2: The 18" will not fit in your 40cm wide enclosure. 18" = ~46cm
I had a Déjà Moo - I've seen that BS before!
Old 22nd June 2019, 08:33 PM   #13
It would loose the sensitivity then
Old 23rd June 2019, 04:44 AM   #14
ICG's Avatar
You can't expect it to go lower AND have high sensitivity, you can't have both. It works on the same principles as a bassreflex enclosure after all. You complained about not going deep enough, that's the solution. If you want more sensitivity, use two or bigger bass drivers. Chose your own poison.
Old 26th June 2019, 05:21 PM   #15
purenv is offline purenv
See Hoffman’s Iron Law
Sub enclosure design questionHide this!Advertise here!
Need help with enclosure design Landoctor Multi-Way 5 3rd May 2019 12:52 AM
6x9 enclosure design question... MyNameIsJake Car Audio 14 3rd January 2019 07:56 PM
Enclosure design audiobahnkid592 Full Range 9 15th April 2007 05:02 AM
Question on enclosure design programs Low Rider Multi-Way 9 5th March 2007 10:06 PM
Need help on enclosure question and xover design ibanezcollector Multi-Way 3 14th January 2006 04:59 PM
Copyright ©1999-2019 diyAudio
