Bass assist via EQ
Bass assist via EQ
Old 18th June 2019, 06:04 AM   #21
GM is offline GM  United States
GM's Avatar
No problemo!
Well duh!
Understood, hence my response.
This I don't understand, though again, not willing to accept WinISD's sims. FWIW, I got good correlation using an early version of LspCad, though have yet to compare it to Hornresp.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th June 2019, 07:18 AM   #22
Brett is offline Brett
Brett's Avatar
Originally Posted by norman bates View Post
I had luck.
Djk referred to it as 6th order assisted.
Works well for low qts drivers.
Small box, high efficiency, super high output.
^^^ This!
djk taught me about this arrangement on AA IIRC back in maybe 99 or 2000 I knocked up some cabs for my 2226's and was amazed that they could have all that clean output in such a small box. I used them in stacks in my PA, later PPSL and have used this alignment at home on several occasions and it's great. I almost never get a response even when I've loaded up sims showing how good it is, even when others are using active xovers and could easily add it. About half the time the responses confuse it with bandpass. I've only ever used it on PA subs (f3 circa 40Hz) or midbasses, never an HT sub.
djk taught me a lot over the years on various fora; I wish I'd thanked him more.
Old 18th June 2019, 08:11 PM   #23
norman bates is offline norman bates  United States
norman bates's Avatar
Yea.
Me too.
Bass assist via EQHide this!Advertise here!
Can someone assist me in building this? AudioSF Multi-Way 24 26th June 2017 12:25 AM
drill assist barney123 Multi-Way 22 13th October 2013 04:49 PM
Would someone assist me with a calculation? homebuilder Multi-Way 11 30th January 2011 06:13 PM
Can anyone assist me in calculating BL? mondogenerator Multi-Way 18 27th October 2009 06:27 PM
Assist software EricD Parts 0 17th September 2007 10:16 PM
Copyright ©1999-2019 diyAudio
