Smallish cabinet for Jbl GT3-12
Old 19th June 2019, 08:19 PM   #11
GM is offline GM  United States
GM's Avatar
Originally Posted by TroelsM View Post
As far as I understand, it would be difficult to cover the whole 50-180Hz with a 4th order BP?
kind regards TroelsM
Your < two octaves is doable, just not with this driver, especially at high SQ in the allotted bulk as you've found out. You want a lower Qt driver with a 50 EBP.
The attached ~177 L sim looks fabulously flat, so probably won't perform well in a typical HIFI/HT app, but the high Qt requires a high compression ratio [CR] to control its relatively weak motor, so might 'grenade' if given much power and why one should avoid high Qt drivers in BP4 alignments.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th June 2019, 06:22 AM   #12
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Originally Posted by BP1Fanatic View Post
In my model, I still reached 180hz with a 130hz lowpass in Filter Wizard.
Yes, the output did reach that high. Sorry. I was thinking about something else.
Kind regards TroelsM
Need more time...
Smallish cabinet for Jbl GT3-12Hide this!Advertise here!
Two mid-sized TH, vs four smallish BR? Cableaddict Subwoofers 7 23rd April 2018 07:35 AM
Smallish 30Hz PA Zwiller PA Systems 20 19th July 2017 03:23 PM
Any Fostex FE167En smallish Cabinet recommendations? Dave the bass Full Range 61 17th July 2012 03:59 PM
2-way + sub or 3-way + sub in a smallish room VEC7OR Multi-Way 23 1st March 2011 04:28 PM
Smallish IB setup Timn8ter Multi-Way 5 27th September 2003 02:11 PM
Copyright ©1999-2019 diyAudio
