passive subwoofer crossover. leads for the woofer(s) are the ones on the crossover as it should be mounted in the sub box. most ive seen are typically 2nd order low and high usually around 125hz and rated for 8ohms per channel. again, in most ive seen, it was typically a dvc woofer then out to satellites. vega had a stealth series, rca had a popular htib for years utilizing them. fun way to make a passive 3 way with off the shelf parts...just pair with your favorite bookshelf speaker and go.
- Subwoofers
- what is it and how does it connect?
