EBP Question - Enclosure Type
Old 18th May 2019, 10:26 PM   #1
davidhozic is offline davidhozic
Default EBP Question - Enclosure Type
Hello,
So i've been designing the subwoofer enclosure of the multi way speaker, EBP is 41.1 Hz which recommends a closed enclosure.
I've asked about this before and I was told it's ok if i went with vented but I just want to make sure so I don't mess up.
I've been using BoxSim to simulate my drivers' performance and it seems to be good according to the simulation.
My question is, how accurate are the boxsim simulations because it seems to be
fine according to Boxsim in a 40 liter vented enclosure? Will it still produce good bass?Does anyone have any experience simulating in BoxSim, and did you get similar results after you've actually built the speaker?
Boxsim project:
4FR10+1WS20e.BPJ - Google Drive
Solidworks screen shot of inside the enclosure:
Old 19th May 2019, 04:47 AM   #2
GM is offline GM  United States
GM's Avatar
Well, 'vented' as in a TL, otherwise one would heavily stuff a BR like it was a TL. No clue how accurate Boxsim is, but you won't get good [mid] bass out of a 40 L BR just as your sim indicates.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th May 2019, 08:57 AM   #3
GM
Ok, would a TL like this be ok?
I do also have some dampening material (wool)
Old 19th May 2019, 09:33 AM   #4
Or maybe something like this?
Could you quickly draw where the best placement for the dampening wool is?
And how would I calculate the tuning frequncy out of this?
Btw, I don't want to make it too complex because I don't want the box bigger than it actually is.
Old 19th May 2019, 11:27 AM   #5
TBTL is offline TBTL  Germany
Try Hornresp
Hornresp
Old 19th May 2019, 12:19 PM   #6
I also don't want to add too much more wood because it's 28 kg as of now
Old 19th May 2019, 12:36 PM   #7
Right, so this is the graph based on the calculation of the whole bottom area being a vent.
Old 19th May 2019, 01:48 PM   #8
Also I'll have almost the entire box's walls covered with polyester to dampen them.
Old 19th May 2019, 02:03 PM   #9
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
What bigger? ...And random use of Wall covering Material give no clue at all if its not specified?
Speaker Design is Engineering, You are very inconclusive when it comes to be specific of what the constraints(dimensional) are for the Freestyle Box suggestion. Wishful thinking and severe physical restrictions for the non suitable Driver(WS-20E) will never result in a good FR extension for the 4 smaller FR-10- HM that should use a vertical C-C distance that is shorter than Lambda/4 at an eventual chosen XO frequency in order to defeat unwanted FR response degeneration interference at the Listening Area.
By the way: Boxsim is OK but restricted for simple Shoe-Box Designs and cannot handle internal Box quarter-wave’s like the Superior Hornresp Program do. If the rear Side of a simple Box is converted into an elaborate Air-way Path's like in a TL: Quarter-waves must be considered and properly handled including the correct use of Wall lining Damping Materials that always is needed.
b
Old 19th May 2019, 03:22 PM   #10
b
This is my first build so for the most part I don't really know what I am doing.
So you're suggesting I should remove the inner side walls based on the drawing or not? The 4 smaller FR 10 Hm's are in passive radiator enclosures.
What exactly do you mean by the "non suitable driver"? I've contacted Visaton about the best box for it and they've responed it's best for a vented (bass reflex or TL) enclosure.
Here are the messurements you've listed in the screenshot + additional messurements (blue = dampening material placement):
The volume of the entire box without anything in it is 150liters. With the 4 enclosures for the FR 10 Hms and the enclosure where electronics are, It's slightly above 127(On the pictures it might seem like there is no backside, the backside is also 20mm thick but I hid it making the sketch for the view of the back and forgot to enable it again)
EBP Question - Enclosure TypeHide this!Advertise here!
What enclosure type is this? el`Ol Multi-Way 9 25th May 2011 08:05 PM
Which type of enclosure adelphia83 Car Audio 5 12th May 2011 12:13 PM
What type of enclosure?? e-side Multi-Way 5 25th December 2005 06:17 PM
Enclosure/constrained layer type question Bill Fitzpatrick Multi-Way 3 29th November 2004 08:13 PM
Copyright ©1999-2019 diyAudio
