Rebuilding the Enigma...
Old 2nd July 2019, 05:57 PM   #61
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Based on this image, looks like you have the vented magnet in the ported section. I say the speaker should last for awhile since the motor is getting cool air while playing.
Old 2nd July 2019, 06:03 PM   #62
Brian Steele is offline Brian Steele  Grenada
Nope - magnet's in the sealed section. I did build the original sub over 15 years ago, when I knew a bit less than I know today .
www.diysubwoofers.org
Old 3rd July 2019, 03:50 AM   #63
BP1Fanatic's Avatar
I see the speaker screws now. The flare of the 2 ports almost make a partial circle that could pass as a magnet.
Old 8th July 2019, 10:58 PM   #64
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by Brian Steele View Post
Will the subwoofer hold up under long-term use? Well, it's only been a week, but it has been used every day of that week for fairly long periods. If it doesn't blow first, I'll do an impedance check on it in a few months to see if there's been any change.
The impedance will not change as long as the VC insulation isn't burnt up. If it is, you won't need an impedance measurement to find that out.
I had a Déjà Moo - I've seen that BS before!
Old 8th July 2019, 11:02 PM   #65
The shape of the impedance CURVE will change however if there's any sort of abuse done to the driver's moving parts.
Old 9th July 2019, 02:50 PM   #66
BP1Fanatic's Avatar
Why not build a v3 with a closed front chamber? Great feature in HR!
Old 9th July 2019, 03:26 PM   #67
ICG's Avatar
No, that's not true. You cannot see any damage to the voice coil until it's too late/gone. The same goes for the cone or suspension, you can see it only if the damage is severe but that will be already audible anyway. The differences between measurements before that point are mostly because of changes in air pressure, temperature and air moisture, they show in the impedance aswell, not only response, distortion or decay.
Old 9th July 2019, 03:28 PM   #68
My experience has shown otherwise, so we will have to agree to disagree on that point.
Old 9th July 2019, 04:01 PM   #69
No need to at this point. However, if they end up blowing the driver again, I'll likely end up designing something entirely different for their use.
Oh, I passed by the bar this weekend. Not unexpectedly, and against my advice, they were using the background music system at top volume again, instead of using the main system. The Enigma (V2) is located below the bar counter (not the best location - but they're wired it up and everything BEFORE asking for my input, sigh), and the counter and floorboards were vibrating, LOL. The subwoofer survived that onslaught intact. I'm sure that they are going to be many more such incidents to come...
Old 9th July 2019, 04:06 PM   #70
ICG's Avatar
You can learn to recognize it by listening to it. It's not difficult.
Rebuilding the Enigma...Hide this!Advertise here!
Another enigma with my "Enigma" Brian Steele Subwoofers 9 4th November 2018 07:27 AM
Audio Analogue Enigma service manual hamradioman Solid State 0 21st August 2015 02:24 AM
Help With DEQ2496 For Subwoofer (Enigma) Gwho Subwoofers 7 15th October 2013 01:11 AM
Someone with Enigma 3 and a scanner: Can you help me? Hybrid fourdoor Music 0 21st September 2003 10:22 AM
I'm rebuilding my amp Lisandro_P Everything Else 2 4th July 2002 08:53 AM
Copyright ©1999-2019 diyAudio
