resources for air impedance
Hey guys,
I am looking for a good beginner resource where i can learn about air impedance. I have been obsessed with ports for longer than I can remember and having been left a bit disappionted with the results of my recent foray into transmission lines....
I believe I need a better understanding of the fundamentals.
There's hope that a book off amazon could solve the cure but a good formula would be a guide as well.
Marc
Thanks GM,
Asking google is great but finding something specific in relation to a topic can be difficult to find... Just thought somebody here would have a good recommendation.
As for the transmission line, yes, I have read alot of material and have done several sims using different types of approaches and although the outcome works; It was underwhelming for the application that I chose.
There is room for improvement however, and that's where I'm hoping to deepen my understanding a bit and thought some direction would be advisable. I will probably just find a rabbit hole on the net somewhere and try to dig my way out as I usually do ;)
Ps: that site is a good resource. thanks for that.
Not sure how much it helps, but the formula for "air impedance" at a given surface is defined as:
Za = p / U
Where:
Za = acoustic impedance (unit is newton-sec/m^5 or mks acoustic ohm)
p = sound pressure (unit is newton/m^2)
U = volume velocity (unit is m^3/sec)
Za, p and U are complex quantities, having real and imaginary components.
Za = p / U
Where:
I have pulled this equation from gm's links and appreciate the clarification.
You said.
"Za, p and U are complex quantities, having real and imaginary components."
Your words have given me alot of intrigue.
Much appreciated.
Just to clarify:
Za = Ra + j * Xa
Where:
Za = complex acoustic impedance
Ra = real acoustic resistance
Xa = real acoustic reactance
j = imaginary operator (-1) ^ 0.5
Za = p / U is the generalised complex acoustic equivalent to Ohm's Law equation V = I * R, rearranged as R = V / I.
Pressure p is the complex acoustic analog to electrical voltage V, volume velocity U is the complex acoustic analog to electrical current I, and impedance Za is the complex acoustic analog to electrical resistance R. Lumped-element simulation models use the acoustic equivalents to electrical circuit networks, when analysing loudspeaker systems.
acoustic imepedance air = Speed of sound x density = 400
Acoustic impedance = p / U, as previously stated.
The unit of acoustic impedance is newton-sec/m^5 or mks acoustic ohm.
Characteristic impedance = p0 * c where p0 = air density and c = sound velocity.
The unit of characteristic impedance is newton-sec/m^3 or mks rayl.
Two different things :).
