THAM 15 vs Cubo 15 vs Cubo 18 ?
Old 14th March 2019, 10:03 AM   #21
chris661 is offline chris661  United Kingdom
chris661's Avatar
I think it's a big box which was IIRC designed for exceptionally high efficiency.
You need to understand that you're up against Hoffman's Irow Law - Small, Low, Efficient - pick any two.
For my subs, I picked 40Hz as my "low", and then played around with the other two to see what I can get.
We can't pick your compromises for you. Your first post says you want a punch in the chest in large venues and outdoors. I don't think two of any of those cabinets will do what you're after. For reference, my PA system will do that, but it's a total of 8x 15"s in ported boxes, loaded with some really good drivers.
Chris
My work: www.grimshawaudio.com
Old 14th March 2019, 04:47 PM   #22
freddi is offline freddi  United States
freddi's Avatar
out of my toys (I'm ~immobile and never done real PA work) this one had a little kick for a cheap 18" driver
Old 14th March 2019, 06:14 PM   #23
martinsson is offline martinsson  Sweden
What do you think of this, is this a good compromise??? a slightly larger THAM 15 box. W22Ē/D24Ē/H30Ē with a B&C 18TBX100
You mean like the THAM18 although it may be slight larger (312dm3 external volume instead of 260dm3 as in your example).
Martinsson's Blog -
Old 14th March 2019, 10:34 PM   #24
Brian Steele is offline Brian Steele  Grenada
Can you spare an inch?
20" x 25" x 30" dual-expansion THAM-style layout, using a B&C 15TBW100. This is without any semi-inductance or lossy Le modelling though. If I can get hold of a ZMA impedance file for the B&C 15TBW100, I'll be able to calculate the semi-inductance parameters and include those in the model.
I think the Dayton Audio PA380 might work in the same box. It has a much lower Xmax, but it's also a lot cheaper.
www.diysubwoofers.org
Old 15th March 2019, 01:18 AM   #25
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi Brian,
FYI:
b
Old 15th March 2019, 01:37 AM   #26
Thanks Bjorno. With semi-inductance enabled, the response looks like the attached (in red).
Old 15th March 2019, 01:54 AM   #27
Lukey123 is offline Lukey123  United Kingdom
Thanks brain Steele. Looks ok, definitely a possibility... the one thatís keeps coming up on top in my sims in the SS15 with a 18tbx100... just trying to find a slightly lighter Driver. And cheaper if I can.
Im only just scratching the the top layer with this program and I donít really understand It fully, and Iím not going to pretend like I do. But I think I get the basics, But this is the best looking result Iíve had so far.
File Type: jpeg 9731B2AD-D577-4F8F-A9E7-0AA30FA7F8CF.jpeg (112.9 KB, 51 views)
Old 15th March 2019, 02:18 AM   #28
From that graph, it looks like the semi-inductance option wasn't enabled for that sim.
If you are set on using an 18" driver in your build, going with a BVR or OSTL alignment might be better, given the restricted dimensions that you have to work with.
Old 15th March 2019, 03:01 AM   #29
Well I had a pair of Yamaha 15” reflex sub years ago, and they were pretty pathetic, you hardly knew they were on.. so I’m slightly reluctant to go back to 15”s even though I know they will be very different. And I don’t want to build 15s and wish afterwards I’d build 18s. So my general thinking is to cut out the middle man and go straight to 18s if I can.
At the risk of sounding very dull, I don’t know what that means ?? What is a BVR or OSTL alignment? I’ve never come across that term before
Old 15th March 2019, 03:06 AM   #30
Originally Posted by Lukey123 View Post
At the risk of sounding very dull, I donít know what that means ?? What is a BVR or OSTL alignment? Iíve never come across that term before
BVR = Big Vent Reflex
OSTL = OffSet Transmission Line
The OSTL should have a wider usable frequency response than the BVR, at the expense of some efficiency.
THAM 15 vs Cubo 15 vs Cubo 18 ?Hide this!Advertise here!
what would be an approximation of a Cubo-Kick in hornresp? freddi Subwoofers 7 16th September 2018 08:45 AM
Kick/Mid/Top cab to match Cubo 12 stuntzahoy Multi-Way 1 27th February 2018 05:08 PM
10x Cubo 21" System Design Basics, power, circuits, and math blockwood PA Systems 4 21st June 2017 08:50 AM
Cubo Sub Erknie Subwoofers 5 1st July 2016 07:34 PM
I think I want to build a TH for bass, Cubo Sub or similar Jimmy154 Subwoofers 22 16th February 2012 03:15 AM
Copyright ©1999-2019 diyAudio
