Eminence Lab15 - Sound Quality
Old 17th February 2019, 10:41 AM   #11
Vintage Audio Projec is offline Vintage Audio Projec
I used the LAB15 in the Tuba THT (low profile version)
It serves as a coffee table pointed at a corner of the room.
Crossed at around 50Hz it goes deep with more then enough SPL.
In normal use it doesn't see much more then 10w and that is when it is turned up loud.
So like always it depends on the enclosure......
They will also work good in a sealed or vented enclosure but I think They are more suited for horn loading (just like the LAB12 was designed for horn loading)
front loaded they are not that sensitive. In a big enough horn it will get scary...
The THT has a long horn path but the mouth is not big enough. Corner loading helps this a lot and makes the Tuba THT work.
So the LAB15 is a great quality driver but a good enclosure makes al the diffierence.
Eminence Lab15 - Sound QualityHide this!Advertise here!
Two sub design options Eminence Lab 12 in 95 liters or Lab15 in 150 litres darkmatter Subwoofers 16 16th June 2018 04:34 PM
Eminence Lab15 and Faital 18xl1800 JaredC79 Swap Meet 0 29th June 2017 02:33 AM
GPA 416/515 + Eminence Lab15 16-500 combo, or? bappe Multi-Way 0 29th November 2014 09:20 AM
Eminence LAB15 NNNTomas Subwoofers 0 21st November 2013 08:13 AM
Eminence LAB15 - 2 (two) each tb46 Swap Meet 0 28th July 2012 02:18 PM
Copyright ©1999-2019 diyAudio
