deep output from very small drivers and enclosure?
Old 7th February 2019, 10:29 AM   #31
Nenola is offline Nenola  Finland
12 liters in kinda small, but the TB 6,5" subwoofer + passive radiators will work in 10 liter enclosure with good results. I pushed the low end with miniDSP and sounds quite good.
The 5" from TB might be the smallest I could imagine as a subwoofer. When going smaller you need to have some gimmicks to get the low notes. In those bt speakers DSP and psychoacoustics are the secret ingredient.
Old 7th February 2019, 04:02 PM   #32
GM is offline GM  United States
GM's Avatar
Originally Posted by botnet View Post
am I understanding correctly that both front and rear horns must be at least 14ft to get some 20hz gain?
Actually, to get gain down to 20 Hz you have to design to ~16.2 Hz, ~14 ft only gets you ~ -3 dB/20 Hz. If you look at the TH I simmed, its path-length is tuned a 1/2 octave below 20 Hz to get full gain.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th February 2019, 02:34 AM   #33
botnet is offline botnet  India
GM
@GM thanks for the simulation, iím trying to interpret the text file - which parameter is horn length? or is the intent to plug the values into hornresp to understand the dimensions?
Old 8th February 2019, 04:08 AM   #34
GM's Avatar
??? Save it to HR's IMPORT FILE, then in HR/File/Import hornresp record/find the file and double click to open it in a new record to view/save/change/whatever.
GM
Old 8th February 2019, 02:23 PM   #35
academia50 is offline academia50  Argentina
Originally Posted by Windforce85 View Post
.........Volume of displaced air is equal to membrane area times its excursion. It is simply not possible to do for small driver............
Well, everything depends on the size and type of the enclosure ..
Another question is whether it is practical, but I think you can achieve important SPL with small speakers ....
PassDiy
Old 8th February 2019, 03:32 PM   #36
DPH is online now DPH  United States
An interesting point of utility for these pico-size subwoofer drivers is as the 2nd or 3rd sub in a Geddes style arrangement. You don't need prodigious output, but unobtrusive packaging.
Happy DIYing, Daniel
Old 8th February 2019, 03:43 PM   #37
hitsware is online now hitsware
I just got a couple of these :
http://www.tb-speaker.com/uploads/fi...0d7350d9af.pdf
Pretty good bang / size
Old 8th February 2019, 05:06 PM   #38
GM's Avatar
Hey Mike, long time no 'see'!
Interesting, wasn't aware of such modular speakers being available to the general public, thanks!
GM
Old 8th February 2019, 06:03 PM   #39
Thank You !
I just ran upon those . Quite a selection .
Sound Module - TB SPEAKER CO., LTD.
They all use passive radiators.
The neat (to me) ones appear to be just
a short tube, driver on one end and passive
on the other.
Old 18th February 2019, 02:14 AM   #40
Default what the world needs ...............
Tang Band T1-1828SD Speaker Module 2-5/16" x 2-5/16"
using that as a model
then upsizing to 4" pvc pipe dimensions
for the ' cab '
probably a coupler
use these :
Dayton Audio DMA Series by Dayton Audio
@ each end of pipe
deep output from very small drivers and enclosure?Hide this!Advertise here!
Can these 10" Focal 10L6411 deliver good, deep bas in decent BR enclosure? gaborbela Multi-Way 2 4th March 2014 03:15 PM
Help picking drivers for small enclosure for large room Huey Multi-Way 11 5th December 2013 05:29 PM
looking for 5 1/4" drivers that handle deep bass tapehead ted Instruments and Amps 69 31st August 2012 10:58 PM
Small footprint SUB using multiple small drivers FredrikC Subwoofers 0 25th August 2010 08:12 PM
Multiple small drivers for large output? diarav Multi-Way 15 29th October 2006 08:39 AM
Copyright ©1999-2019 diyAudio
